SOURCE: Water heats but stops perculating
Check the spring under the grounds basket on the pump tube. This is supposed to hold the end of the tube down in the heater well. It should compress when the lid is pushed down on the basket and twisted to lock in under the handles. I have found a good source of parts for Faberware urns and percolators at goodmans.net. The thermostats and heating elements can be easily replaced and the urn returned to original condition. Rich of Colorado
SOURCE: Hamilton Beach 40616 Perculator
Try to replace the delivery (ascending) pipe in the middle.
Hope this can help you
SOURCE: some water is steaming and not going through the
Hello jfortnideone,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with
the easier solution first. In the DCC 1200 there is a filter "stick or
column" in the left rear. Pull it out and remove the clogged carbon
filter(s) that are in there. Shine a light into the receptacle and
remove the debris in the bottom. It is likely that this is causing the
problem with you machine needing to be started on multiple times. See
if this solution works. If it does, you might run 8 cups of water and
4 cups of vinegar through to help decalcify the units plumbing. Do this
once or twice and then rinse with at least one pot run-through of
clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following:
unplug the unit and lay it on its back. You will need a #10 torx
driver (hardware store if you don't have one) to remove the bottom
cover plate. There are 4 torx screws holding it on. When removed, you
will find 2 orange hoses. Carefully attempt to remove the left hose
without splitting. I used a eyeglas screwdriver to loosen it up. If
it splits, just cut off the split and stretch it to reconnect when time
comes. As you look into the hose you will find a little black valve
inside as well a some gunk. Clean it all out with a fine wire as best
you can. Rinse well. Attempt to reconnect the hose back onto the
pipe. Slip the pipe clamp back into place. Replace the cover and
screws and you should be good to go again. This is not as daunting as
it may seem. You can do it. :o) Good luck! If this answer helps,
please leave positive feedback for me. Much appreciated. Regards,
NormanZ
SOURCE: Lost the users manual for the Farberware 155 Automatic Perculator
Hi. 3 scoops of coffee to 3 cups, Them adjust from there, bobbyone
