20 Most Recent
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Questions & Answers
PROBLEM WITH LOW FLOW/PRESSURE IN GAGGIA COFFEE DELUX COFFEE MAKER
the most likely reason for poor flow through the brewhead is a blockage in the outlet valve.the outlet valve is behind the shower disc holding plate and can be removed with 13mm socket. a straightened paper clip needs to be insrted in the outlet to clear any internal blockage,then pump water through. if the outlet valve splits in two ensure the rubber bung is inserted upwards.once refitted all should be fine
Gaggia Classic won't turn on, no light at power switch
I would suspect rough handling of your suitcase, leading to some loose or broken connections inside. I recommend opening it up and looking for obvious disconnections. If you don't see any, the next step will be to use a tool like an electrical continuity tester (which can also test for a blown fuse). There is a lot of information about Gaggia Classic repair online -- just search for "Gaggia Classic repair".
I have a Gaggia "coffee" and no water goes through
Remove the 2 allen wrench screws under the screw and screen, this will drop the diffuser, careful do not loose spring and plastic ball that is in there. Then run machine without parts in place to check if water goes through. If yes replace parts minus screen and screw and test, it taht works insert screen and screw and test.
I have a Gaggia "Coffee"
First thing I would check is the end of the steam wand to make sure it is not blocked. Then if you are getting hot water for making espresso, I would remove the top cover and check the topmost thermostat.
I descaled my Coffee Deluxe machine and am now
Water is supposed to flow through the four holes then to the screen, then the coffee, so if you are not getting any flow through the screen then either the holes in the diffuser are blocked or the screen is dirty.
