20 Most Recent
Faberware 12-55 Cup Coffee Urn Questions & Answers
How much coffee per cup?
One tablespoon per cup. Or 2.50z to 3.0oz of coffee for 12 cups depends on your taste
Strong coffee add more coffee or if you like light coffee less coffee.
Don't let the coffee sit for long time in this kind of brewer. More than 30 min. is going to kill the flavor.
How much coffee do I
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Model 155B thermostat
Best place I've found to get Farberware parts is Goodmans. Check back occasionally, they get parts that they previously didn't have. Here is the link:
http://www.goodmans.net/s/1/c_farberware%2bcoffee.htm
What is the spacing size between pins on the electric cord
Measure the pins center to center. There are three common spacings.
1/2 inch, 11/16 inch and 1 1/16 inch..
Appliance cords are available at most hardware stores including Lowes, Home Depot, Menards and even in the electrical departments of many other stores. If you have your old cord it is easy to compare the plugs. There is a 3/8 inch difference between the 11/16" plug and the 1 1/16" so it is easy to see the difference.
I need pamp
I think you mean PUMP. Go to repairshack.com Good luck. Ron
