Dryers Logo
Posted on Jan 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sears model 970-c87192-10 electric dryer. No heat. changed the thermodisc and thermostat safety, still no heat. Element is sparking when you turn on the dryer.
Richard Roth
Level 3:
Top Expert:
  • Dryers Master 9,472 Answers
  • Posted on Jan 06, 2011
Richard Roth
Dryers Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629115
Points
28464
Here is a video to walk you thru the troubleshooting process.
3answers
Dryer spns but there is no heat
probally the heeting element
Whirlpool electric dryer high thermostat replacement
test all this steps in according with your model, electric or gas. God bless you
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer.
Jul 21, 2013 • Dryers
2answers
Dryer goes on and spins but no heat. I've opened up the back but what now? Is there a specific part that if blown would cut off the heat? Model is a small one - probably cost about $300 - don't know the...
The thermal cut-off at the top of the heater duct/housing blows when the high-limit thermostat below it fails to cycle the heating element on and off properly to regulate the heater temperature. This thermal cut-off along with high-limit thermostat including the cycling thermostat on the blower housing are wired in series with the heating element and power to it is cut when the thermal cut-off blows as a safety feature to prevent fire. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
Dryer will not produce heat. Dryer turns on and drum turns. Runs quiet but no heat. Clothes do not dry.
It is possible you need to replace your heater element or your thermostats .. depending on your model which you did not list. Your element and thermostats will cause it not to heat ... when you get your model go to www.sears.com/parts and you can possibly view your schematic if sears had ever sold it... get an ohm meter there cheap Lowe's home depot sears test for power on each of the three. clean the venting also..
May 25, 2010 • GE Dryers
Dryer not heating up
check your air flow coming out of dryer if it is good and stong then you should change the high limit safety thermostat and the cycling thermostat.
Electric dryer heating element overheats then shuts off
Good be your heating element had a weak coil when it heat up it lose it volt recheck your element
Jul 15, 2017 • Dryers
No heat
Check the resistance of the heating element (8 to 14 ohms). If ok, then check continuity of the overload devices attached to the heat element duct. If either one or both are open then replace ($14 for both). Dryer should heat.
If heat element is faulty, the part can be purchased at Sears/Kenmore Parts Center and swapped out ($45.00).
Provide your dryer model number and ask for the needed parts.
Unplug your dryer first before attempting any service work. Safety first and always!
2answers
Kenmore Electric Dryer Model # 110.62622101
Wedge, one red wire to the right terminal of the heating element. The safety thermostat should of had a piggy back that fits over the left side terminal of the element and connected to one side of the safety thermostat. Other red to other side of safety thermostat, Orange from the timer (smaller connector) to the respective connection on jumper. Catriver.
Top Dryers Experts
john h
