20 Most Recent Roper REX4634KQ Electric Dryer Questions & Answers
Sounds like you've got a bad motor.
Roper REX4634KQ... | Answered on Feb 22, 2019
open the door to dryer,look around the opening where you put the clothes in and send the full model number on your question you have REX4634KQ and three different models show up and parts are not the same,could possibly be a bad timer but the only way to tell is by checking with a meter
Roper REX4634KQ... | Answered on Feb 02, 2018
Sounds like thermal cut off fuse has blown. That is indicative of airflow obstruction somewhere either internally in the dryer or venting from dryer to outside v
Roper REX4634KQ... | Answered on Nov 15, 2017
either your heating coil is damaged or you have a bad resistor in the back of the panel ...any tech can take a look and tell...the resistors run about 20.00 the coils on the other hand may turn out to be as high as 200.00 plus labor..hopefully it is the resistor..GOD bless
Roper REX4634KQ... | Answered on Sep 18, 2017
Its common for coins left in pockets to dislodge from the clothing. Most times you see them in the drum. On rare occasion they can get into places that could damage dryer. However since there is a burning smell it is not something to guess about. Being that it is less than a year old it should be warrantied, if it is not a mal-funtion you would still want to fix it. Call Lowes and set up a service call
Roper REX4634KQ... | Answered on Aug 18, 2017
Likely failure of door latch and dryness sensor. The sensor may be just dirty from use of dryer sheets and needs to be cleaned with window cleaner.
Roper REX4634KQ... | Answered on Jun 10, 2017
repairs should be performed by an authorized repair person. the heating element coil may be broken and grounding itself the the module housing. if so replace the heating element.
Roper REX4634KQ... | Answered on Jun 04, 2017
Start buttons seldom fail, but door switches fail often.
Have someone good at this open the lid and bypass the door switch, it should start fine.
Door switches can be bought at Amazon or "Sears Parts Direct" or e-bay.
God bless your efforts.
Roper REX4634KQ... | Answered on Mar 10, 2016
check the heating element and the limit switches there are the first things to look for when theres no heat
Roper REX4634KQ... | Answered on Dec 15, 2015
YOUR HEATING ELEMENT IS BAD OR YOUR HEATER BOX FUSE IS BAD,IF YOU HAVE A METER YOU CAN CHECK THEM BOTH-LET ME KNOW-MIKE
Roper REX4634KQ... | Answered on Dec 12, 2015
wow a water pump on a dryer new one on me
Roper REX4634KQ... | Answered on Mar 13, 2015
I had the same problem. I called the repair man and my heating elements were broken, I had them replaced and now my dryer works fine. For me getting it repaired was cheaper then buying a new one. Your repair man should give you a free estimate on the cost
Roper REX4634KQ... | Answered on Nov 13, 2014
Hello there and thank you for choosing fixya
You will need to test the thermal fuse and see if it is bad. It should read closed for continuity. If it is open, check the vent and see if it is cloged or kinked. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps. How To Check Continuity With Ohmmeter
Read more: http://forum.appliancepartspros.com/dryer-repair/277220-dryer-wont-turn.html#ixzz1U5vnbtDk
Roper REX4634KQ... | Answered on Nov 08, 2014
Is this a digital control dryer or does it have a timer, and I would check the door switch if it does not shut off when you open the door,
Roper REX4634KQ... | Answered on Oct 19, 2014
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Roper REX4634KQ... | Answered on Sep 16, 2014
The dryer must be connected to a 240 volt 3-prong outlet. If the voltage is not sufficient, you may have a problem with the electric supplier. What kind of problem are you having that leads you to believe the voltage is not sufficient?
Roper REX4634KQ... | Answered on Aug 17, 2014
Electric clothes dryers all have at least one sometimes several temperature switches mounted along the heater elements enclosure.
This switch is designed to detect extreme temperature and allow the the heater elements to turn of to prevent overheating.
The switches are generally only about 6 bucks a piece and have two two screws to hold them in place
When they start to go bad , they typically do just what yours is doing , shuting off and becoming stuck in the off position never clicking back on . As a field appliance tech I have repaired may of these . You could expect to pay about 120-160 for the repair if your not handy enough to take on the task.
Hope this was helpful.
Best of luck.
Joe Chiera.
c5cfeb88-6980-4592-b473-40b12cbf8987.png 2b108d08-d50e-4254-bb2f-a104a7a5bc16.png
Roper REX4634KQ... | Answered on Jun 11, 2014
Roper REX4634KQ Electric Dryer Logo
701 questions posted
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
View Most Popular
Roper Dryers
  • Roper Dryers
Most Popular Question
start button nothing
  • Dryers
