My wife and I both hate the laundry process. As a very characteristic, I purchased 2 Bosch 500 and 2 steam dryers. Initially she told me I had only doubled the pain until about 12 month in. One of our washers was giving us the e27 error, we were totally beside ourselves- only one washer with the same 3 boys and one prepubescent daughter. We looked for a fix all over and found this. Sure enough it works set the button to cotton - cold took us 5 minutes of beeping and then it reset. Amazing!!! Thank you. We will now go on to our ever so spoiled life. FYI if u have a big family 2 washers and 2 dryers is money well spent
I just had the same exact problem. Did your repairman ever figure it out?
I had the same problem. Did your repairman figure it out?
The repairman did not get a chance to come back, because in between both visits, I contacted my Sears salesman, who talked to someone at Bosch and offered me the secret quick-fix: set your washer to Cotton-Cold, ignore the error signal and leave it for a few minutes (between 5 and 20 should do the trick). This apparently acts as some kind of reset for the error code. It worked for me! I have been happily doing washes for a week now! Hope this helps you too.
It worked! Thank you so much. I had bought a new switch and it did not remove the error code. Who would have thought something as simple as that would reset it. Thank you again
Glad I could help.
I can't beleive it worked..Thank you all !!!!
A code E27 means a problem with the door lock. Try
unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right
corner you will see a white plastic pull cord. Pull the cord and pull open the
door. If that doesn't reset the door lock you will need to replace the lock.
HI THAT MEANS door is locked and will not start PLZ VISIT THIS LINK
http://laundry.manualsonline.com/support/bosch/washer/error-code-e27-3495138
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
