Xerox WorkCentre M15i Laser Printer Logo
Posted on Jan 05, 2011
Will not power up - Xerox WorkCentre M15i Laser Printer
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4253
Points
18
I have same problem at a customer. But i got here (in fixya) some solution... take out power supply unit,,, in smps, replace two capacitors... c21/c25... i have yet to do it. try it. give feed back. all the best
2answers
Where is bcm located on 04 nissan armada
It's not the BCM ,more then likely it's that windows switch .
Rear Door (LH or RH) REAR POWER WINDOW SWITCH LH OR RH OPERATION WINDOW UP When the rear power window switch LH or RH is pressed in the up position Power is supplied ? through rear power window switch LH or RH terminal 4 ? to rear power window motor LH or RH terminal 2. Ground is supplied POWER WINDOW SYSTEM GW-17 C D E F G H J K L M A B GW Revision: January 2005 2004 Pathfinder Armada ? through rear power window switch LH or RH terminal 5 ? to rear power window motor LH or RH terminal 1. Then, the motor raises the window until the switch is released. WINDOW DOWN When the rear power window switch LH or RH is pressed in the down position Power is supplied ? through rear power window switch LH or RH terminal 5 ? to rear power window motor LH or RH terminal 1. Ground is supplied ? through rear power window switch LH or RH terminal 4 ? to rear power window motor LH or RH terminal 2. Then, the motor lowers the window until the switch is released. MAIN POWER WINDOW AND DOOR LOCK/UNLOCK SWITCH OPERATION WINDOW UP When the main power window and door lock/unlock switch (rear LH) is pressed in the up position Power is supplied ? through main power window and door lock/unlock switch terminal 3 ? to rear power window switch LH terminal 3 ? through rear power window switch LH terminal 4 ? to rear power window motor LH terminal 2. Ground is supplied ? through main power window and door lock/unlock switch terminal 1 ? to rear power window switch LH terminal 2 ? through rear power window switch LH terminal 5 ? to rear power window motor LH terminal 1. Then, the motor raises the window until the switch is released. When the main power window and door lock/unlock switch (rear RH) is pressed in the up position Power is supplied ? through main power window and door lock/unlock switch terminal 5 ? to rear power window switch RH terminal 3 ? through rear power window switch RH terminal 4 ? to rear power window motor RH terminal 2. Ground is supplied ? through main power window and door lock/unlock switch terminal 7 ? to rear power window motor RH terminal 2 ? through rear power window switch RH terminal 5 ? to rear power window switch RH terminal 1. Then, the motor raises the window until the switch is released. WINDOW DOWN When the main power window and door lock/unlock switch (rear LH) is pressed in the down position Power is supplied ? through main power window and door lock/unlock switch terminal 1 ? to rear power window switch LH terminal 2 ? through rear power window switch LH terminal 5 ? to rear power window motor LH terminal 1. Ground is supplied ? to main power window and door lock/unlock switch terminal 3 ? through rear power window switch LH terminal 4 ? through rear power window switch LH terminal 3 ? to rear power window motor LH terminal 1. Then, the motor raises the window until the switch is released
2helpful
Atx motherboard wiring diagram
For the power cables from the Power Supply? Or Power Supply, and Front Panel header on the motherboard?
For both of these you need to state the computer manufacturer name, and Model Number.
Post back in a Comment.
If you just wish a generic, one-size-fits-all explanation;
A) 20 or 24-pin ATX main power cable.
The older computers use a 20-pin ATX main power cable. As computers needed more power to the motherboard, the 24-pin ATX main power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll the page down for info on the 24-pin ATX main power cable.
[ Much older motherboards (AT) used two main power cables. { In the link - Original PC main power cables} ]
B) 4-pin ATX +12 Volt power cable.
Was brought out because Processors needed more power, than the 24-pin ATX main power cable feeding the motherboard, could deliver.
Power for the Processor,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) 4-pin standard Peripheral power cable
Commonly misnomered as 'Molex'.
Molex was a model name given by the first manufacturer, of this design of power cable connector.
The name stuck. Kind of like referring to an adjustable open-end wrench as a Crescent wrench.
It is also referred to as a 4-pin Standard Peripheral power cable, because there are two styles of 4-pin Peripheral power cables.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Generally used for IDE (PATA) harddrives, and IDE optical drives.
4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Older computers used it for power to the Floppy Drive. It's generally used now to provide power for a Card Reader.
Note that both types of connectors use the same power wires, and 2 ground wires.
Yellow is 12 Volts
Red is 5 Volts
Black is Ground
[ Also, in the ATX main power cable:
Orange is 3.3 Volts, the Green wire is the Soft Power On wire. Abbreviated as PS_ON.
Power Supply plugged into power, the Soft Power On wire is briefly touched to ANY Ground wire. This is bypassing the Power On switch.
If the computer (Power Supply) comes on, you have a bad Power On switch.
IF the computer (Power Supply) does NOT come on, you have a bad Power Supply ]
(ALL Black wires are Ground wires. They all lead back to one central Ground point.
ALL power wires lead back to one point in the power supply, for EACH power wire.
The 12 Volt power wires, (Yellow), all lead back to one point in the Power Supply.
This is the 12 Volt power rail.
The 5 Volt power wires, (Red), all lead back to one point in the Power Supply.
This is the 5 Volt power rail.
The 3.3 Volt power wires, (Orange), all lead back to one point in the Power Supply.
This is the 3.3 Volt power rail ]
D) SATA power cable
15-pin power cable for SATA harddrives, and SATA optical drives,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ The smaller 7-pin SATA connector is the interface cable, or data cable.
IF, you have a SATA harddrive that has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
It will burn out the harddrive if you use both. It may not do it right away, but eventually it will.
I have had people state over the years, that they were using both power cables. Came back two months later to tell me their harddrives had burned out ]
More to follow in a Comment.
Regards,
joecoolvette
4helpful
2answers
I need to find out how to remove the power steering pump on a 2006 pontiac grand prix 3.8L
Power Steering Pump Replacement
Removal Procedure
1. Remove the accessory drive belt.
2. Raise and support the vehicle. Refer to Vehicle Lifting.
3. Remove the tire and wheel assembly.
4. Disconnect the power steering pressure hose from the power steering pump.
5. Disconnect the power steering return hose from the power steering pump.
6. Disconnect the harness connector (4) from the power steering pump (1).
7. Remove the power steering mounting bolts from the power steering pump.
8. Remove the power steering pump from the engine.
9. Remove the power steering pump pulley from the power steering pump.
10. Remove the power steering pump reservoir from the power steering pump.
Installation Procedure
1. Install the power steering pump reservoir to the power steering pump.
2. Install the power steering pump pulley to the power steering pump.
3. Position the power steering pump to the engine.
Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts.
Tighten the bolts to 25 Nm (18 ft. lbs.).
5. Connect the power steering pressure hose to the power steering pump.
6. Connect the power steering return hose to the power steering pump.
7. Install the harness connector (1) to the power steering pump (4).
8. Install the accessory drive belt.
9. Fill the power steering system with fluid.
10. Bleed the power steering system.
11. Operate the power steering system and inspect for power steering system leaks.
*This originally came from abauto
2helpful
5answers
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
1helpful
How to replace power steering pump impala 2000,engine 3.4
1. Place a drain pan under the vehicle.
2. Remove the accessory drive belt from the power steering pump pulley. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
5. Remove the power steering pressure line from the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L)
6. Remove the power steering return hose from the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Remove the power steering pump mounting bolts from the power steering pump.
8. Remove the power steering pump assembly.
9. Remove the power steering pump pulley from the power steering pump. Refer to Power Steering Pulley Replacement.
10. Remove the power steering pump reservoir from the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
1. Install the power steering pump reservoir to the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
2. Install the power steering pump pulley to the power steering pump. Refer to Power Steering Pulley Replacement.
3. Position the power steering pump assembly to the engine. Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts. Tighten the power steering pump mounting bolts to 34 Nm (25 ft. lbs.).
5. Install the power steering pressure line to the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L).
6. Install the power steering return hose to the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
8. Lower the vehicle.
9. Install the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L
10. Fill the power steering system. Refer to Refilling the Power Steering System.
11. Bleed the power steering system. Refer to Bleeding the Power Steering System.
12. Inspect the power steering system for leaks. Refer to Steering and Suspension Leaks.
13. Remove the drain pan from under the vehicle.
You may want to take it to the dealer or other repair shop. It is very difficult and will consume a major portion of your day.
1helpful
2answers
3210 printer won't respond!!! I cannot print out anything on this printer, but it was working one month ago!?!?!
Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  1. Unplug the power supply from the rear of the product.
  2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
  3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the power module.
  6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
  7. Check to see if the power module has an LED.
    • If the power module does not have an LED, continue to the next step.
    • If the power module has an LED, check to see if the LED lights up.
      • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
      • If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
33helpful
2answers
2004 Pontiac Grand Prix V6-3.8L VIN 2
Power Steering Pump: Service and Repair
NOTE: The content of this article / image reflects the changes called out by TSB: 05-02-32-004.
Removal Procedure
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
