20 Most Recent HP Photosmart D5160 InkJet Printer Questions & Answers
3answers
Flashing red light on display
1st step - print a self test report Press and hold the OK button. Then press the left arrow key one time. Release the OK button. The test page prints OR Press the OK and Help keys simultaneously. The test page prints print the test pages 4 time minimum 2nd step - reset the printer If the printer is not off, press the Power button to turn it off. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the printer. Unplug the universal serial bus (USB) cable from the back of the printer, if connected. Wait 30 seconds, then plug the power cord back into the printer. Plug the power cord back into the wall outlet. Press the Power button to turn the printer on. Ensure that the memory card has been removed from the memory card slot. Make sure plain paper is loaded in the In Tray. Hold down the OK button and press the Right arrow button four times. If the test page prints, re-connect the USB cable to the printer. OR IF YOU ARE NOT ABLE TO DO SO THEN start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen. 3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual. 4th step - visit www.hp.com left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD click on that in the next screen a tab comes up mentioning FOR PRODUCT enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it choose the OS under DRIVER YOU HAVE OPTIONS LIKE - » HP Basic Driver (recommended) » HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
2/9/2022 12:39:41 AM • HP Photosmart... • Answered on Feb 09, 2022
D5160 error code 07874dd6
Same here. Seems no way.
2/17/2021 8:39:50 PM • HP Photosmart... • Answered on Feb 17, 2021
Hp D5160 prints testpage after each print
Salve La stampante Photosmart HP D5160 dopo l'accensione inizia a produrre rumori come ingranaggi che si graffiano ripetutamente nell'area vicino al cassetto di sostituzione delle cartucce, alla fine dopo alcuni istanti la stampante smette di fare rumore ed ? pronta per la stampa, ma ultimamente, dopo sopra, sistematicamente non viene pi? stampato e il punto esclamativo rosso lampeggiante rimane. Le cartucce sono originali e hanno una capacit? superiore ai 3/4. Spero in tuo aiuto il prima possibile. Grazie. Roberta
2/25/2020 5:05:24 PM • HP Photosmart... • Answered on Feb 25, 2020
2answers
Help, I have lost my
You can download the Softwares/Drivers for your printer from these links (similar with the contents on the Hp CD) :
Hp Photosmart D5160 Printer for windows xp 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL15834/dj-41864-2/TF_regna_psp_NB.exe
Hp Photosmart D5160 Printer for windows xp 64 bit
or
Hp Photosmart D5160 Printer for windows vista 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL18384/dj-47558-2/SF_CDA_Full_Non-Network_enu_NB.exe
Hp Photosmart D5160 Printer for windows vista 64
or
Hp Photosmart D5160 Printer for Windows 7 32 bit
or
ftp://ftp.hp.com/pub/softlib/software11/COL30907/dj-76773-1/SF_CDA_NonNet_Full_Win_WW_130_140.exe
Hp Photosmart D5160 Printer for Windows 7 64 bit
or
Hp Photosmart D5160 Printer for Linux
For Mac Drivers, please visit here and follow the instructions given there.
It would be much easier for you and for me if you had mentioned the Operating System installed on your computer where you are going to install the printer. Anyway, select the suitable link for your operating system.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
2/4/2019 11:09:31 AM • HP Photosmart... • Answered on Feb 04, 2019
0answers
C4eb9421
Be the first to answer 6/10/2014 3:38:39 AM • HP Photosmart... • Posted on Jun 10, 2014Be the first to answer
0answers
Error d6
Be the first to answer 4/19/2014 3:12:15 AM • HP Photosmart... • Posted on Apr 19, 2014Be the first to answer
0answers
Error 03
Be the first to answer 4/7/2014 3:45:54 AM • HP Photosmart... • Posted on Apr 07, 2014Be the first to answer
Red light blinking
The Attention light is flashing red. Solution The printer requires attention. Try the following: * If the printer is connected to a computer, check the computer screen for instructions. * If you are printing a CD label on a CD/DVD, insert the CD/DVD holder in the CD/DVD tray now. * If you have a digital camera connected to the printer, check the camera screen for instructions. * If the printer is not connected to a computer, check for the following problems: - Main cover open - Out of paper - Paper jam - Print carriage jammed or stuck - Print cartridge missing or inserted incorrectly - Print cartridge tape not removed - Incorrect print cartridge installed - Packaging materials are not removed * If you are unable to solve the problem by using the instructions above, turn off the printer and unplug the printer power cord. Wait 10 seconds, and then plug it in again. Turn on the printer.
2/18/2014 8:22:17 PM • HP Photosmart... • Answered on Feb 18, 2014
0answers
0answers
The printer is saying the cover is open but it is not
you may have a bad cover sensor!
1/21/2013 10:42:57 PM • HP Photosmart... • Answered on Jan 21, 2013
HP Photosmart D5160 InkJet Printer Logo
172 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
help lost
  • Office Equipment & Supplies
