Thank you for your post, friend!
Based off what you are describing it sounds like a possible issue within your control panel or door switch of your Frigidaire freezer, LFFH21F7HW6. You have completed a reset on your appliance by disconnecting power. I would recommend seeking assistance from a professional to properly diagnose and repair your freezer. Hope this is helpful. -Matt
Hello friend, thank you for your post!
I see that your door ajar alarm is going off when the door is closed to your Frigidaire freezer. It sounds like a possible issue with the control panel or switch. Let's perform a reset to your appliance to see if that will correct the issue. You can do that by disconnecting power from the appliance for roughly ten minutes. I hope this helps. -Matt
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
