Computers & Internet Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to install wnce2001 without WPS and cannot get passed step 3. The browser does not open a setup page.
Anonymous
Level 2:
New Friend:
  • Expert 88 Answers
  • Posted on Dec 22, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
88
Questions
Helped
27385
Points
272
Sometimes the setup wizard flow stops when you run through setup wizard over IE6 and IE7. It won't happen on other browser, because it is a Microsoft browser bug.
Workaround: Click "Refresh" of browser to re-run the setup wizard again or use other non-IE browser to run through setup wizard.
1helpful
2answers
I am trying to connect my canon pixma 452 printer to my samsung tablet. Where is the WPS button ?
WPS Connection Method Before we start, there are some conditions that must be met in order to use the WPS push button method:
  • The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.
  • Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.
Step 1 1. Press the [Setup] button (A) on the printer.
Step 2
1. Select [Wireless LAN setup] and press the [OK] button.
The blue Wi-Fi lamp (A), will light up when the wireless connection is enabled.
The printer will now automatically search for access points supporting the WPS feature
Step 3
The display on printer should be as shown below:
(The message will read: "Press WPS button about 5 sec. and press [OK] on the device)"
1. Press and hold the [WPS] button on the access point.
For exact instructions on starting WPS on your access point, please refer to its user guide.
2. Press the [OK] button on the printer within 2 minutes.
The blue Wi-Fi lamp on the printer flashes while searching for or connecting to the access point.
Once connected, the following screen will appear. Press the [OK] button.
If another screen appears, please refer to "troubleshooting" in the user guide.
This concludes the WPS setup procedure.
Please now proceed by installing the software to make the most out of your PIXMA MX474.
  1. If you do not have the installation CD that came with your product, please download the manuals and software.
If the WPS wireless setup is still failing after following this guide, please Contact us for further assistance. 1 888 224 4280
tip
In Belkin router if u have error message as unidentified networks?
Hi Friends,
If you have the error message as UNIDENTIFIED NETWORKS when you connect a wireless belkin router to a Wireless Computer then please follow the standard steps as follows,
Step 1:Connect the Router with a Ethernet cable to any one of your Computer and Check if you are able to see the Wired light in the router at front end of the Router
Step 2:Open Internet Explorer and type 192.168.2.1 and Click on Enter Button in the keyboard
Step 3:Now,you will be able to see the belkin router setup page
Step 4:On your left hand side,Click on Wifi Protected Setup(WPS),now it will prompt for a Login Password,Leave it blank and click on Submit
Step 5:Change the WPS as Disable and Click on Apply Changes
Step 6:After it has Applied the Changes and bring back to the same page,go to the Laptop computer and search for wireless networks in the range.
Step 7:You will be able to see the Network name try to connect to the network it will be getting connect and you will be able to go online.
This is a standard steps for this problem.This arrives only in the WINDOWS 7 Operating system when connecting the router in the wireless.
WPS button
I have a WRT54G router and there is no WPS button.
This is a cut and paste from Cisco engineer:
Wi-Fi Protected Setup or WPS is a somewhat new feature on most routers. However, I believe that the WRT54g was release prior to this feature. The installation disc for your wireless adapter is trying to circumvent network discovery and the process of entering a wireless password by using the WPS feature. Without using the installation disc to setup the adapter should still be able to connect to your Wi-FI network. Only use the disc to install the drivers for your wireless card and the wireless access utility. After you have done this:
1.Open the wireless utility and you should see available networks
2.Select your Wi-Fi network
3.If the network is open (not password proctected) you should be connected immediately
4.If the network is secured (password protected) then you will prompted to enter your password or preshared key
5.After entering the key you should be granted access to the network
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Have a dlink print server dpr1040 and dlink wireless router how do i print wireless
DPR-1040 information - http://www.dlink.com.au/products/?pid=777
All of this is from the manual located at link above under the resources tab.
Wireless Setup
WPS (Push Button Configuration)
WPS simplifies the process of connecting to a wireless network to a touch of a button. To use WPS you must have a WPS compatible wireless router,if you do not then you will need to manually configure the wireless connection in the web configurator (see Web Configurator below).
1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, press the WPS button located on the side of the DPR-1040. The blue LED should start flashing repeatedly.
2. Within 120 seconds, press the WPS button located on the wireless router you will be connecting to. This button may also be located in the router's web configuration pages labeled "Push Button Configuration (PBC)".
3. If successful, a wireless connection will be established between the two devices.
This connection is secure and uses automatically generated encryption keys; you do not need to remember them.
Note: If you experience problems connecting to a device, please try again. If you still experience problems, the device you're connecting to may be incompatible with the DPR-1040. Also, make sure you are connecting to a router or access point (AP).
Web Configurator
1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, type the IP address of the DPR-1040 into your browser, the default IP address is 192.168.0.10. If this does not work, use the PS-Link utility to find out the IP address.
2. Upon accessing the web configurator, click Setup > Wireless Setup.
3. On the next screen, enter the wireless network settings as provided by your network administrator.
4. Click Apply Settings, the DPR-1040 will restart and the wireless setup is complete.
Note: If your wireless connection does not work, check that you have entered the correct network settings into the Wireless Setup screen.
The wifi connection to this belkin play max is not stable, sometimes get connected, sometimes not. i connected the external hard drive to the usb port, at first i can see the drive using belkin router...
OK let me disable something in your router
QOS
Supported Products - Play Wireless Router (F7D4302), Play Max Wireless Router (F7D4301)
Using QoS rules on your Belkin Router helps provide both bandwidth and priority to network traffic so it can pass without its performance being affected. It allows users to classify traffic of applications and provides them with differentiated services (Diffserv).
Setup Steps
  1. Click on the green Belkin Router Manager icon (right-click for Windows) to open the menu.
  2. On the Belkin Router Manager menu, scroll up to Router Settings and highlight.
  3. Click to open the Belkin Router Setup page on your Web browser.
You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button.
  1. From the QoS Profiles page, you can easily set up QoS rules.
  2. Click the "Apply Changes" button to save your settings.
Also disable WPS and Firewall in router.
let me know .
please don't forget to rate techbelkin
I can't establish a wireless conection on any of my laptops. I have a Belkin N wireless router. If iI do get a connection the strenghth is only fair.
Hi Friend,
Please follow the below mentioned steps,
Step 1:Open a Internet explorer and type 192.168.2.1 and click on enter key
Step 2:You will see a belkin router setup page
Step 3:On your left hand side click on Wifi protected setup(WPS)
Step 4:Now it will ask for password,you leave it blank and click on submit
Step 5:Now change the WPS to disable and click on Apply Changes
Step 6:On your left hand side of the page click on Channel and ssid
Step 7:Change the Wireless Channel to either 1 or 6 and click on Apply Changes
Step 8:Now you check the Signal Strength,it will be better than before and you will have a good speed
If you have clarification, feel free to reply
Regards,
Ayyasam
Wireless signal not connecting when more than 3 meters away
You have disable one of the option in the router,please follow the steps
1.Type 192.168.2.1,in the browser
2.you will get a belkin routre step up page
3.on your left hand side,click on WifiProtected setup(WPS),it will ask for password,leave it blank and click on submit
4.I wold be enabled change it to disabled and click apply changes
Regards,
Ayyasam
4helpful
3answers
Security(wps) light not lit on router
You need to setup the wireless security ON on the router by loggin in to router setup page for that you need to connect the router with a ethernet cable with the computer or laptop and open the router setup page with router IP in internet browser, if you can tell me the model number of the router and brand i can give you step by step process to setup the security on the router.
on selecting the security as any apart from none the light comes on
Let me know if this will help
Regards
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
