20 Most Recent D-Link DIR-412 Mobile Broadband Wireless Router (790069333040) Questions & Answers
Hi i just purchased a
Did you capitalize Admin? It's capitalized in the manual, and user names are usually case sensitive. If you can't get through the login process, you probably won't get the connectivity, either. The manual says set the switch on the back to 3g mode during setup. After checking that, you might try using the RESET button on the back - while the router is powered, press and hold for 10 seconds and release. After the router restarts, reboot your computer and try connecting again.
5/3/2017 2:51:25 AM • D-Link DIR-412... • Answered on May 03, 2017
My Dir 412 router was
First try a new LAN cable between you router and the internet modem. Reboot both your modem and router. Connect directly to you internet modem to make certain it is staying connected to the internet. If not then you have a modem service issue. If OK, then The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
1/6/2017 8:37:00 PM • D-Link DIR-412... • Answered on Jan 06, 2017
2answers
How I put a password
How to recover my login Facebook password
7/1/2015 7:24:18 AM • D-Link DIR-412... • Answered on Jul 01, 2015
Why my sprint netgear broadband is not shutting down
If the power button does not work, unplug it.
12/8/2014 7:15:37 AM • D-Link DIR-412... • Answered on Dec 08, 2014
My cell phone internet does not work in the house wps not lighting up on router
What type of router do you have? Please be more specific. Thanks!
10/18/2014 10:36:11 PM • D-Link DIR-412... • Answered on Oct 18, 2014
2answers
How do i connect my
try to use port forwarding, Just go to your routers webpage, then advance and look PORT FORWADING option, set the port for your PS3 then assign an IP on it then save and exit. Hope it helps thanks.
6/9/2014 8:38:14 AM • D-Link DIR-412... • Answered on Jun 09, 2014
Connecting bigpond 7.2 to d-link dir-412
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
6/11/2012 4:28:23 AM • D-Link DIR-412... • Answered on Jun 11, 2012
Have a dlink print server dpr1040 and dlink wireless router how do i print wireless
DPR-1040 information - http://www.dlink.com.au/products/?pid=777All of this is from the manual located at link above under the resources tab. Wireless Setup WPS (Push Button Configuration) WPS simplifies the process of connecting to a wireless network to a touch of a button. To use WPS you must have a WPS compatible wireless router,if you do not then you will need to manually configure the wireless connection in the web configurator (see Web Configurator below). 1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, press the WPS button located on the side of the DPR-1040. The blue LED should start flashing repeatedly. 2. Within 120 seconds, press the WPS button located on the wireless router you will be connecting to. This button may also be located in the router's web configuration pages labeled "Push Button Configuration (PBC)". 3. If successful, a wireless connection will be established between the two devices. This connection is secure and uses automatically generated encryption keys; you do not need to remember them. Note: If you experience problems connecting to a device, please try again. If you still experience problems, the device you're connecting to may be incompatible with the DPR-1040. Also, make sure you are connecting to a router or access point (AP).Web Configurator 1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, type the IP address of the DPR-1040 into your browser, the default IP address is 192.168.0.10. If this does not work, use the PS-Link utility to find out the IP address. 2. Upon accessing the web configurator, click Setup > Wireless Setup.3. On the next screen, enter the wireless network settings as provided by your network administrator. 4. Click Apply Settings, the DPR-1040 will restart and the wireless setup is complete. Note: If your wireless connection does not work, check that you have entered the correct network settings into the Wireless Setup screen.
5/23/2012 10:16:25 PM • D-Link DIR-412... • Answered on May 23, 2012
HI GUYS Can you help me
1. may be that the usb has not met the requirements for the laptop.
may need updated drivers to operate properly with the windows operating system in this case could be windows 7
check the requirement for the device.
9/7/2011 10:31:02 PM • D-Link DIR-412... • Answered on Sep 07, 2011
Dlink dir-142 Dodo usb prepaid dongle
plug the usb modem into usb slot of pc as normal.
Bridge the connection between the internet connection and ethernet router connection in network page.
Set router to ip add etc and it should share net access while pc is turned on atleast.
9/6/2011 11:23:14 AM • D-Link DIR-412... • Answered on Sep 06, 2011
Have just brought a dlink
1. check the firewall setting in Windows
2. check the firewall setting in the router and the wireless allowances in the wireless list for device ( located in the wireless router
3. you must allow a wireless device to access the router.
the data from the web for the device is not reaching the pc to display the pages
this is by permissions in the router and the firewall
4. check your anti virus settings also.
8/12/2011 11:39:30 PM • D-Link DIR-412... • Answered on Aug 12, 2011
The setup wizard does not
For each PC that needs to connect to the DIR-412 wirelessly, you must ensure that the correct Wireless Network Name (SSID) and encryption key has been entered.
Windows 7 On your computer, go to Control panel --> Network and Sharing Center and Click on "Connect to a Network then select on the Wireless Network Name (SSID) and enter the password/encrytion key.
Windows XP On your computer, go to Control panel --> Network Connection then under the network task pane select View available wireless networks then then select on the Wireless Network Name (SSID) and enter the password/encrytion key.
7/25/2011 10:27:15 AM • D-Link DIR-412... • Answered on Jul 25, 2011
I'm trying to set up
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
7/17/2011 8:05:09 AM • D-Link DIR-412... • Answered on Jul 17, 2011
Can not get to the
Use the reset button on the back of router to reset to factory settings. The default IP after that will be 192.168.1.1 Otherwise, make sure you're connected to the network properly and that you have the right IP address in the browser.
7/11/2011 12:44:57 PM • D-Link DIR-412... • Answered on Jul 11, 2011
I am trying to connect a wirelsss printer to my 3G
I have an easier way to find your passphrase, but ONLY if you have a computer connected to the router wirelessly. Logging into the router and trying to find out the passphrase can sometimes not work either because a lot of the time, it is blanked out for security reasons, of course.
This program finds saved passwords on your computer for wireless access points. You can read more about it here, if you'd like, but the first link gets you right into the action.
6/12/2011 6:38:46 PM • D-Link DIR-412... • Answered on Jun 12, 2011
Lost my installation cd for
http://www.dlink.com.my/support/support_detail.asp?idproduct=438
here is the link for the drivers for the dir412
6/11/2011 1:02:51 PM • D-Link DIR-412... • Answered on Jun 11, 2011
D-Link DIR-412 Mobile Broadband Wireless Router (790069333040) Logo
49 questions posted
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
dlink dir 142 dodo usb prepaid dongle
  • Computers & Internet
