I,
It depends how you reinstalled the OS in the computer, was it using the recovery discs or retail XP disc. Using recovery discs if you are installing, everything should work fine. This scenario may occur if you have used a retail OS disc to reinstall the OS.
Anyways try the below mentioned troubleshooting steps:
Install the Original Video Driver from the below link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTX650PB&upd_id=2149&os_id=7
After this install Origial VAIO Event Sevices:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTX690P&upd_id=1975&os_id=7
Then, install VAIO Event Service Update.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTX650PB&upd_id=2287&os_id=7
At last, install the AV Mode Utility app:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNTX650PB&upd_id=2040&os_id=7
Install the drivers in the same order, this should work. VAIO Event Services take cares about the FN keys, after installing all these drivers, restart the computer and check if the VAIO Event Service is running at the startup.
Thanks!!!!
