20 Most Recent
Sony VGN-CR320E/P Notebook Questions & Answers
I upgraded my laptop sonyvaio
you might need to download the driver software again which you can do so by visiting the Sony official website and searching for your laptop model.
2/21/2013 7:31:39 PM •
Sony...
Answered
on Feb 21, 2013
The web cam not work
hi Have you checked the drivers for this application ,is it showing the icon in your programs 1) Go to the Control Panel (Make sure it's on classic view)
2) Click on add hardware
3) Click next
4) Make sure the Recommended choice is chosen
Wait for it to search for new hardware...
5) Click next
6) Double-Click on 'Show all devices'
Wait for it to get the list of all of the devices... this may take some time... I mean a lot of time...
7) Choose the manufacturer on the left hand side and choose the model on the right
8) Press next to start installing
Wait for it to install... This may take some time... or a lot of time... again... but more...
9) Press Finish
hope this help you goodluck
7/3/2011 11:06:53 AM •
Sony...
Answered
on Jul 03, 2011
My webcam not work and
Please install the following Webcam Drive and check if that works.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR320EP&upd_id=3353&os_id=28
All the best!!!
7/2/2011 2:22:02 AM •
Sony...
Answered
on Jul 02, 2011
Sony vaio vgn cr320E không
For the model # VGNCR320E/P, Sony has not released XP Drivers, but you can try the XP models for the other computer models. I have checked and found that all the drivers of the below mentioned VAIO matches with your model except Blue tooth. So do not install the Bluetooth driver in the below link.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR115E&SelectOS=7Please let me know if you are able to install the above drivers. Please get back to me if any issues.
Thanks!!!!
12/21/2010 8:15:16 PM •
Sony...
Answered
on Dec 21, 2010
After downloading Windows 7 my
u will need drivers for the cam....but for that you will have to register your Win7 copy and make full updates to your Win7....if your copy is legal go to MS website and register your copy and update....
all drivers for your system will be installed only based on your legal copy..... else you will have to go back to old OS....
Win7...has limitations of driver for hardwares as many mfgs of HW have not created drivers for the old HWs....as the Win7 OS source code to create drivers have not been provided by MS to them.....
11/3/2010 6:17:59 AM •
Sony...
Answered
on Nov 03, 2010
Wireless detection is faulty.
Hi Thanks for your question.
You can try and change the channel that router is broadcasting on. This can be an issue sometimes. Change it to something popular like channel 4 or 8. I hope this was helpful. Good Luck
5/8/2010 5:22:35 AM •
Sony...
Answered
on May 08, 2010
SONY VGN-CR320E
if you want to use it on an external monitor just download and install the latest drivers for your video card with the monitor plugged in the problem with you lcd is probably the ccfl went bad they are mini flourecent lights inside the lcd you need to dismantle the lcd then remove the old ccfl and solder in the new ones here is a link that sould help with the installation
http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx
10/7/2009 6:40:55 PM •
Sony...
Answered
on Oct 07, 2009
Problem in Sony Vaio VGN-CR320E´s motheboard
would you have been happier if you had a 3-year warranty on your machine? I suggest you try to compare between buying a new motherboard to buying a whole new notebook...the latter usually is more reasonable. Again, get an extended warranty
8/16/2009 2:23:46 PM •
Sony...
Answered
on Aug 16, 2009
VGN-CR320E webcam did not work
Please check in the Device Manager whether Sony Visual Communication Camera Driver is listed under the "Imaging Devices" category. If it's there and have exclamation mark, please right click on it and Uninstall it. If not listed then download and install the webcam driver from the link given below.
http://www.esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR320E&upd_id=3353&os_id=28
Furthermore, please refer to the help files of the application you're trying to use the web cam with to know how to configure web cam with the particular application.
6/24/2009 2:41:39 AM •
Sony...
Answered
on Jun 24, 2009
CD/DVD Drive doesnt show
Right-click on the exe. file and see were run as administrator is click on it and then try to run the exe file again
5/31/2009 3:17:35 PM •
Sony...
Answered
on May 31, 2009
Driver
plz check the manufacture website
7/23/2008 2:33:13 PM •
Sony...
Answered
on Jul 23, 2008
