Magic Chef Chest Freezer MCCF5WBX Logo
A
Anonymous Posted on Dec 16, 2010
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on Dec 18, 2010
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
580072
Points
4327
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER - spacer.gif 5.5 Cu. Ft. Chest Freezer Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
1helpful
Can a kenmore chest freezer model 253.16502101 also run as a fridge?
No, only a select few catering appliances can be a fridge or a freezer depending on the temperature setting. Yours is a freezer.
https://www.google.com/search?q=kenmore+chest+freezer+253.16502101+specs
Cubic feet for Frigidaire Chest Freezer MFC13M4FW3
Good Morning, thank you for your question! This particular unit is a 12-13 cubic foot freezer. If you have further questions, please do not hesitate to reconnect.
3helpful
2answers
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
There is a small hole in my g.e. chest freezer.
that is the drainage hole where water can pass out from .
Freezer not keeping foods frozen
If this freezer is running all of the time and only freezing the walls at the top inside it is a good chance there is deteriation in the piping in the walls eg (rusty pipes) letting the refridgerant escape (common fault) with chest freezers.If it is more than 7 years old it would be advisable to replace it as the repair would probably cost 3 quarters of replacement price.Hope this helps. Kind Regards.
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 • Freezers
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
2helpful
2answers
Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Top Magic Chef Freezers Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
