20 Most Recent
GE 7 cu. ft. Chest Freezer FCM7DR Questions & Answers
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
My freezer is not working. The light on the front
check first the convenience outlet or the main breaker reset if trip off or replace together the cord test it the continuity using ohmmeter also check the over load protector of the compressor replace if busted. also check the bulb if busted replace it.
I just dropped a frozen turkey to the bottom of my
Good day,
Your idea was a good one, and it should not be neglected. The area your going to tape should be warm and dry. Best long term repair, would be to cut a small piece of aluminum, and epoxy it in place. The machine will need to be warm long enough for the epoxy to set, however, it should be a permanent repair.
Our freezer stopped freezing model fcm7drawn
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Many times a freezer and/or refrigerator
do not work right because of a dirty condenser coil...there are also many other
things that can go wrong.
If you are hearing a clicking or buzzing then check out the
last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start
trouble shooting your unit...and something that you can do rather then calling
a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Ge chest freezer wiring diagram
Great question but I cannot answer it. GE makes several models of chest freezers and they are not all wired the same. My eyesight is not to good and I cannot see your freezer so I cannot answer your question. You might try our friend google and look for the make and model of your freezer with the prefix schematic.
10/2/2021 4:24:47 AM •
GE Freezers
Answered
on Oct 02, 2021
