20 Most Recent
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Questions & Answers
Switch comes on and goes off but compresser wont
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.If your refrigerator is running but warm, then...Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...Refrigerator Condenser Coil Cleaning Refrigerator RepairRefrigerator Troubleshooting Refrigerator CompressorRefrigerator Compressor Start Capacitor and Start Relayheatman101
Power off for electrical repair.
This sounds as if its a start relay problem. They are attached to the compressor
You will need the model and serial number to get a new one at the appliance
parts store. They are usually under a plastic cover on the side of the compressor
and the cover is retained by a metal spring clip. Remember to unplug unit before
replacing this part. The model and serial number should be located near the compressor.
Light not working in GE chest frezer
Check the bulb, check the tabs within the socket, check the door light switch.
Please, unplug fridge when testing these. We'd like to hear from you again.
Chest freezer, stopped freezing, Ptc relay
Some of the PTC relays just give out for no apparent reason. (the brown ones more than any other) But in your case you can see physical signs of overheating. I would suspect the compressor has seized up, or has a shorted winding.
