20 Most Recent GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR Questions & Answers
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
GE 13.7 cu. ft.... | Answered on Apr 19, 2016
  • When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
  • The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
GE 13.7 cu. ft.... | Answered on Dec 11, 2013
I tell customers to plan on a full 24 hours to get to optimum temp. And yes, there will be heat on the exterior.
GE 13.7 cu. ft.... | Answered on May 05, 2013
I looked at the parts diagram (GE model#FUF14SUDRWW) on Searspartsdirect. I didn't see an actual on/off switch, but it does show a temperature control switch in the inside of the unit. On some of the freezers, if you turn the knob all the way to the left, it acts as an off switch and kills the unit. It looks like the knob inside the cabinet, on the lower back right side (it could be upper..hard to tell by that diagram). If there is no knob, but an empty hole, then the knob is missing and you might have to turn the shaft with pliers to check it. If you get a click at one limit of the switch when it is turned, that means it is acting as an on/off switch. If nothing happens when turning it after the click, I would suspect a bad switch. Since the lights nor compressor are working, it would point at a switch. You can probably find it cheaper than Sears by googling the part # WR09X10064. I saw it as low as $84 at some of the appliance parts site. A local place might have a used one for cheaper.
Hope this helps
GE 13.7 cu. ft.... | Answered on Aug 16, 2011
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
GE 13.7 cu. ft.... | Answered on Nov 15, 2010
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
GE 13.7 cu. ft.... | Answered on Jun 07, 2010
Try changing relay.
GE 13.7 cu. ft.... | Answered on May 04, 2010
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
GE 13.7 cu. ft.... | Answered on May 02, 2010
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
GE 13.7 cu. ft.... | Answered on Apr 21, 2010
Change the motherboard.
GE 13.7 cu. ft.... | Answered on Apr 07, 2010
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
If the relay is ok the sealed system may have lost its charge of freon and you would need a qualified tech to check it.
GE 13.7 cu. ft.... | Answered on Apr 05, 2010
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
GE 13.7 cu. ft.... | Answered on Mar 31, 2010
not necessarily. It could be the start components for the compressor. should test them out. Also, check compressor for grounded windings.
GE 13.7 cu. ft.... | Answered on Feb 25, 2010
the red is the thermostat light while the orange is temperature light.
GE 13.7 cu. ft.... | Answered on Feb 20, 2010
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
GE 13.7 cu. ft.... | Answered on Jun 09, 2009
it should be notated on the compressor on the door and maybe inside the fridge. if my memory serves me correctly i think the clean air act states that it should contain r22. if nothing else you can call GE's support line and they can answer that question.
Good luck
GE 13.7 cu. ft.... | Answered on Jan 14, 2009
GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR Logo
Popular Tags
31 questions posted
Top GE Freezers Experts
craig nesmith
Level 1 Expert
AJMAL KHAN
Gil Shultz
Are you a GE Freezer Expert? Answer questions, earn points and help others
View Most Popular
GE Freezers
  • GE Freezers
Most Popular Question
yesterday dad brought me working ge
  • Freezers
