20 Most Recent Woods 4.3 cu. ft. / 122 liter Chest Freezer C04NAS Questions & Answers
Bought this Chest Freezer from a Rummage Sale. Its
Try the gargler and google the maker and model.
2/9/2021 8:30:46 AM • Woods 4.3 cu.... • Answered on Feb 09, 2021
0answers
Lost key
the keys they use are not very high security,so pop along to a local dealer and offer him $20(?) dollars as a deposit, to "borrow" some keys so that you can try them at home,and when you find the right one,get some cut.....may take a couple of trips,but its the easiest way.take some tags to mark the showroom models of the keys,so when you return them(same day)you only need to pop them back in the unit in the showroom.do you know that the ladies will get more joy,if they talk to a femail assistant.
9/10/2010 9:53:24 AM • Woods 4.3 cu.... • Answered on Sep 10, 2010
The battery light on my
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/26/2010 12:02:57 AM • Woods 4.3 cu.... • Answered on Aug 26, 2010
Hinds do not hold the chest freezer door open, need new ones
Call 1-800-673-1262 Give model number.
7/25/2010 2:07:17 AM • Woods 4.3 cu.... • Answered on Jul 25, 2010
Woods freezer yellow light looks light a snow
Does it sound like it is never shutting off/ It may mean it is over freezing. Also for good measure >>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
4/21/2010 8:44:34 AM • Woods 4.3 cu.... • Answered on Apr 21, 2010
Freezer stopped running
Here is how to check if the thermosat is bad.
make sure you have 120v to one side of the t'stat. it is just a switch so one side is hot and the other side is not.There are two wires going to the t'stat'. you need to jump them (put them together) if you do this and the compressor kicks on, then replace the t'stat. if it doesn't come on then the t'stat is good. something else is wrong.
check to see if this unit has a timer. check the compressor to see if there is 120v.
i could not find any info on this freezer
Woods parts are not coming up. best bet is call:
partstown.com and appliancezone.com
i tried your model but it didnt come up
but anyways ask them if they at least carry parts
4/2/2010 5:36:31 AM • Woods 4.3 cu.... • Answered on Apr 02, 2010
Freezer not keeping foods frozen
If this freezer is running all of the time and only freezing the walls at the top inside it is a good chance there is deteriation in the piping in the walls eg (rusty pipes) letting the refridgerant escape (common fault) with chest freezers.If it is more than 7 years old it would be advisable to replace it as the repair would probably cost 3 quarters of replacement price.Hope this helps. Kind Regards.
12/8/2009 7:54:34 AM • Woods 4.3 cu.... • Answered on Dec 08, 2009
2answers
If the freon leaks from my freezer will it freezes
If it leaks it won't freeze anything for long it will soon turn hot.
9/10/2009 12:53:05 PM • Woods 4.3 cu.... • Answered on Sep 10, 2009
Where can I buy a seal for my Woods upright freezer Model WV20-ZF1/E
Woods are no longer in business and all parts are obsolete. https://www.google.com/search?q=Woods+upright+freezer+WV20-ZF1%2FE+door+gasket So, you can either buy a door gasket by the size of the one you have, or you can make one by buying a length or door gasket material and cutting 90' notches in the 4 corners and filling / gluing the corners with white silicone. Or if the gasket is just split, you can clean thoroughly and repair with silicone. Fill the void, close the door, and clean up excess. https://www.searspartsdirect.com/model/3d1c1uazs3-003083/wc-wood-v20wb-upright-freezer-parts And then after typing all the above, I searched for the Part Number and there is one here! https://maxappliances.ca/product/woods-0-90000-046-wp4357142-gasket/ ..
10/31/2023 3:01:10 PM • Woods Freezers • Answered on Oct 31, 2023
Woods Freezer. Where is the off position on it please?
Question edited for clarity. Question moved from Cars and Trucks category. Freezers don't have controls INSIDE the freezer, as it is too cold for efficient operation. Chest freezers have them on the outside behind the grille where the compressor is. Upright freezers usually has electronic controls on the door. You give o clue as to what type you have or what model you have. You can easily turn it off by removing the wall plug! Or you can find the manual. 'Off' on a thermostat is normally fully clockwise. https://www.google.com/search?q=woods+freezer+manual ..
3/18/2023 4:21:10 PM • Woods Freezers • Answered on Mar 18, 2023
Woods C1017w3 chest freezer lid wont stay up??
Look at the back. There are counterbalance springs under the plastic hinge covers.
3/12/2022 7:28:54 PM • Woods Freezers • Answered on Mar 12, 2022
What can I do? My Woods upright freezer model F17WCE has stopped freezing. It is still cold, but not cold enough freeze.
Hello; My name is Peter. I am a retired field service refrigeration technician. How do you know you fully defrosted the freezer? You have a defrost timer and heater to do that. Unplugging your unit for a few hours may not be enough. You need to remove the lower back wall cover. There are several screws holding it on and the rubber molding around it easily pulls out. Up plug your unit and remove the lower back cover. 1.) Frozen Drain - Your unit goes through a defrost cycle every 8-10 hours. During the time your freezer shuts down for 20-30 minutes except for your light. If you have a frozen drain, the condensate builds up behind the lower back wall until the cooling(evaporator) coils become plugged up and you do not get any air flow. You may even have a solid block of ice. Repair: Using a hair dryer (DO NOT Use Metal Objects. You may damage the coils.) slowly defrost the coils. This will take 2-3 hours. 2.) Cooling (Evaporator) Fan Failure - Assume the coils are not iced up. Is your evaporator fan running? 25386473-x2invnbvdad3ve0pcsobo2og-2-0.jpg Part #: 3-60336-001 Cost: $115.00 Check it out: With a multi-meter set to the lowest Ohms (Omega Symbol). Is the motor humming, Then it is bad and needs to get replaced. Unplug the unit. Disconnect the motor. Put one meter lead in one connector socket and the other lead in the other motor sock. You should get a reading of "0" Ohms if the motor is good. Anything else the motor is bad and need to be replaced. 3.) Defrost Timer - Pull your unit out to access the lower back. With your unit plugged in, take a small flat head screw driver, insert it into the slot on the time. Turning clockwise one turn at a time, until the freezer shuts off. If you have turned one full cycle, then you have a bad timer. Ok. The unit shut down except for the light. Observe the metal bar below your cooling coil. Is it hot? If not then you may have a bad defrost heater. Lets check it out - Unplug your unit. Once again with your multi-meter set on the lowest Ohms, disconnect each ends of the wire connectors. Be careful not to touch the fins on the cooling coil. They are razor sharp. The connector are hard to pull apart. Put one meter lead in one connector and the other meter lead into the other connector. If you do not get a Ohm reading between 50-250, then you have a bad defrost heater. 25386473-x2invnbvdad3ve0pcsobo2og-2-2.jpg Substitution: 3-80405-003 Cost: $56.00 This is a glass tube with a spring in it. If it is burner or the spring is broken then you have a bad defrost heater. 4.) Refrigerant Leak or Obstruction - With the unit plugged in. Lay the lover cover the cooling coils. Close the door and wait 30 minutes. Remove the cover. Do all of the coils have a nice frost pattern? Is there a block of ice in the upper right hand corner of the cooling coil. If so you either have a refrigerant leak or an obstruction. In this case the repair will cost you $450.00-$500.00. 5.) If all of the above is good, then you may have a Bi-mel problem. In the upper right hand corner of your cooling coil there is a thermostat. This controls the temperature and compressor start-up. This may explode in the back. Check to see if it is intacted. 5.) Bad thermostat - These can not be checked for failure. If you have check all of the above this may be your problem. 25386473-x2invnbvdad3ve0pcsobo2og-2-5.jpg Substitution: 4-83053-003 Cost: $68.00
3/2/2022 4:52:08 AM • Woods Freezers • Answered on Mar 02, 2022
Looking for a three wire connector for a woods chest freezer lid
post a picture of it
1/26/2021 7:45:11 PM • Woods Freezers • Answered on Jan 26, 2021
I have a Woods upright freezer model #V17MUA. the date says 9701, would that mean January 1997?
Could be. Check with Woods to confirm.
12/9/2020 9:05:58 PM • Woods Freezers • Answered on Dec 09, 2020
What is an equivalent to the Woods Freezer F20HDA? I need a new gasket. Measures 32X60
Terry Jul 05, 2020
You might try contacting the vendor's web site for wherever it was purchased. Similar Woods Freezer model parts are available of the searspartsdirect.com web site for a different model: https://www.searspartsdirect.com/model/o...
12/1/2020 11:30:44 AM • Woods Freezers • Answered on Dec 01, 2020
Woods 4.3 cu. ft. / 122 liter Chest Freezer C04NAS Logo
17 questions posted
Top Woods Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Woods Freezer Expert? Answer questions, earn points and help others
View Most Popular
Woods Freezers
  • Woods Freezers
Most Popular Question
bought chest freezer from rummage sale
  • Freezers
