20 Most Recent
Kenmore Freezer 8.8 cu. ft. Chest Freezer with Hose Adapter Questions & Answers
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sear chest freezer stop working model#2539139180
The compressor probably shut off on thermal overload. This protects the compressor from burning up. What has happened is that a capacitor or evaporator has gone bad or it could be low on freon. Have someone take a look at it. However, if it is older than 8-10 years old, consider replacing it. This could be the beginning of the end.
Sears freezer 32539139180 not freezing
Is this a new one. If it is older than 8-10 years, get anew one. The cost of a compressor if that is it, will cost more than the hassle. But then again, it may be a t'stat which is fairly easy to replace. These things , freezers, are cheap now adays. Once you replace something on it, it usually is the beginning of the end.
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
Where is the 9V battery located on a Kenmore upright freezer model 970
The location of the 9V battery on a Kenmore upright freezer model 970 can vary depending on the specific model and design. However, in general, the 9V battery is typically located in the control panel or on the back of the freezer near the compressor. You may need to consult the freezer's manual or contact Kenmore customer support for more specific information regarding your model.
