Hello, You probably have a clogged Carburetor. To clean the Carburetor, you will probably need to remove, disassemble, soak, and use compressed air to blow out the jets in your carburetor. Pay close attention to how the carburetor is attached to the engine. Make a drawing if you need to or take some pictures. Remove the Carburetor from the engine. Remove the air filter, linkages, throttle/choke cables and fuel lines as needed. Remove the mounting bolts/nuts. You will need to disassemble the carburetor as far as possible and put it in some Carburetor cleaning solution. You can get this at any auto parts store. Do not place rubber parts in the solution. Allow it to soak in cleaner as directed, and then blow out the ports and jets with compressed air immediately after you take it out of the cleaning solution. Be careful not to get any spray back on your skin or in your eyes. Reinstall the Carburetor in the reverse order. Replace any worn or torn gaskets or o-rings as you assemble and reinstall it. If it starts after you are finished with the cleaning, but still runs a little rough, you will need to adjust the high-speed mixture setting on your Carburetor. Turning the high-speed screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however you do need a special tool that is very hard to get your hands on. They don't make many engines with plain screw heads on the jet screws anymore. The newer Carburetors are factory set lean so they can pass emission standards. If you have a local dealer, they should adjust the mixture for a couple of bucks. If you can adjust the screw, start the engine, allow it to warm up, and apply full throttle. Start backing off the screw just until the engine gets max RPM. That's it. You're done.
My name is Dane and I am going to assist you in solving your problem.
Just a TIP: Always mix your fuel with an approved fuel stabilizer. Fuel begins to go bad after a few months and that's why many people have fuel problems in the spring.
I hope I
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
Refill fuel tank with an 2-cycle Oli/gas mixture.
40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
Remove the spark plug.
Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
Remove the pull cord assembly (4-bolts)
This reviled the crank shaft-Pull cord bracket
I use a large monkey wrench to turn the shaft (CW) Clock-wise.
Complete approximate 20 revolutions.
Reassemble, but don't install the spark plug yet.
Complete approximate 20 more revolutions
by pulling the pull cord.
Use q-tips to swab the top of the piston, as much as possible.
Install the spark-plug and crank, it will smoke for amount 7-10 minutes
