KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
Anonymous Posted on Dec 07, 2010
I put the plug of 110v into 220v and it blew the circuit,they came back on but not the mixer.could it be a fuse on the mixer?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
781
Points
Where did you get the diode on the circuit board? I did the same thing with my kitchen aid:(
Anonymous
Level 3:
  • KitchenAid Master 43,501 Answers
  • Posted on Dec 07, 2010
Anonymous
KitchenAid Master
Level 3:
Answers
43501
Questions
0
Helped
10845550
Points
101584
No, you have turn that mixer into a boat anchor....it will cost more to fix it then it is worth...
heatman101
  • 1 more comment
  • Anonymous Dec 22, 2010
    It just needs a new circuit board, ($35-50) or repair the old one ($5-10). But, if the quality of these new Kitchenaid mixers is as low as I suspect it to be then heatman may be right in his estimate of cost to repair vs. value..
  • Anonymous Dec 23, 2010
    Thanks ,ur were right,it was a diode on the circuit board,glad i tryed to fix it b4 throwing it into the ocean as heatman said, it.cost me $15.00.thks
  • Anonymous May 20, 2011
Conversion 110v to 220v
Hello there,
We do provide a conversion kit to assist you with your job. Please see below the link for your perusal:
KSM150CONVUK KitchenAid Conversion Kit for KSM150 to 220v/230v/240v with UK Plug https://secure.kaparts.co.uk/sku/KSM150CONVUK
Where can I fix a circuit board in Spain or UK
I'm sorry but that sounds like a total loss. International power stanarf is 220v but US is only 120v. Likely all electronic circuitry is burned out. It would be cheaper to get it replaced since the board, motors and anything else electric will need to be replaced. Next tome get an international adapter that dials down 220v to 120v if you order anything else from US.
1helpful
I put 240v to 110v motor.will it be just a new motor?
You probably blew out the soft start circuit. You can buy new ones at appliance parts stores if you are handy.
How to convert kitchenaid mixer from 220v to 110v
It's perfectly save to use a power converter from 220v to 110V. The 50Hz Frequenz will let the Motor spin 20% slower. So it'll last forever. I use a KSM90 from the US in Germany for more than 25 years. It runs great and the gears inside it look like new.
1helpful
2answers
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
1helpful
2answers
110V 6ohz - 220V 50hz
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
1helpful
Kitchenaid mixer professional motor
DO NOT DO IT. The Hz will destroy the morotr. The transofrmer only converts the voltage. You are better off buying a 220V version.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
