20 Most Recent KitchenAid KSM150PS Artisan Series Stand Mixer Questions & Answers
Hiya,
It sounds like you need to adjust the head height on your mixer.
I have added a link below for our help page on adjusting your mixers head height.
https://www.youtube.com/watch?v=bmg8SVldZbs
I hope this helps you :)
KitchenAid... | Answered 3 days ago
Hiya,
Sorry to hear you are having trouble with your mixer.
It may be that your motor brushes are worn down or have been put in incorrectly.
I have added a link below for our help page on replacing your motor brushes:
https://www.youtube.com/watch?v=5YuS3atXR0M
I have also added a link below if you wish to purchase a set of new motor brushes:
6778011 KABrushSet KitchenAid Mixer Motor Brush Set (2 x W10380496 brushes) https://secure.kaparts.co.uk/sku/6778011
Hello there,
Sorry to hear you are experiencing an issue with your appliance, it sounds like you might need a new tilt lever. Please see below the help video for your perusal as well as quote for a replacement one, should it need replacing:
4176024 KitchenAid Lever-Latch Black was 9709280, 9709267 tilt https://secure.kaparts.co.uk/sku/4176024
KitchenAid... | Answered on Oct 09, 2019
Raise the head and adjust the screw that is now exposed from the front over the top of the bowl where the head hinges on the pedestal. Screw out to raise the head up.....anti clockwise.
KitchenAid... | Answered on Oct 07, 2019
If it's just the wire beater attachment, then it's possible it's oxidation from the metal/aluminum. Did you put it in the dishwasher? The manual says not to put the wire beater in the dishwasher. Hope that helps.
KitchenAid... | Answered on May 17, 2019
Hiya,
It sound like the hinge pin keeps making its way out, which can be fixed by tightening grub screw that sits inside the pedestal (you will need to turn the mixer around) or you could purchase a Super Hinge Pin, which will NOT work its way out - please see the relevant links below:
http://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/HowtoremoveyourhingepinfromyourKitchenAid/tabid/637/Default.aspx
http://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/KAPartsSuperHingePinforKitchenAidMixers/tabid/599/Default.aspx
You can purchase the Super Hinge Pin here:
KA3009 KitchenAid Tilt Head Mixer Super Hinge Pin Upgrade Kit https://secure.kaparts.co.uk/sku/KA3009
ALSO - it sounds like you need to adjust the head height of your mixer - please see the link to our help page below:
http://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/KitchenAidHeadHeightAdjustment/tabid/598/Default.aspx
KitchenAid... | Answered on May 10, 2019
I had the same problem. Part #25, the "control plate assembly" It has a set of points on the lower, inside. These points turn the motor on. You can watch it as you go from off to stir. If at that setting the motor doesn't start, be very careful and bend the lower point contact up just a bit. The 2 points should make contact earlier, and turn the motor on.
KitchenAid... | Answered on Apr 07, 2019
What part number did you order for the beater and what is the model number for the mixer? Also is the mixer brand new, or did you get it used and it just started happening?
KitchenAid... | Answered on Feb 19, 2019
Hi ROBYN, Happy New Year! First a couple of clarification questions: A) Was your ice-cream maker a Kitchenaid (KA) Ice Cream maker, too, and B) was your mixer purchased after 1990? If you purchased a KA Ice Cream maker and your mixer is less than 20 years old, according to KA, the Ice cream maker should fit all mixer produced after 1990.
If you have a different brand (not KA) of ice cream maker, then I’m afraid you just won’t just be able to replace the drive assembly, but you will also need the correct dasher (the scraper inside the freeze bowl), as such you probably would be better off purchasing a KA Ice Cream Maker, which would be compatible with your mixer. Of course if your mixer is over 20 years old, then even if you have a KA Ice Cream maker, it may not fit correctly anyway, which leaves you in a conundrum. Should you purchase a new KA mixer for your KA Ice Cream maker or do you purchase a new KA Ice Cream Maker to go with your current KA mixer produced after 1990?
You can download the KA Ice Cream Maker Use & Care Manual from the KA website at: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KICA0WH_Use%20and%20Care_EN.pdf
I wish I could offer you a better solution to use your new ice cream maker with your current mixer, but unfortunately I am unable to do so.
I hope this was helpful, even if it doesn’t provide you the answer you were looking for. Good Luck, Howard, Burke, VA. If this solution was helpful though, please rate it. hslincoln
KitchenAid... | Answered on Oct 04, 2018
Where do you see the visible sparking?? There are two places in the mixer where this could / should happen. One is at the brushes where they meet the commutator on the armature of the motor. I don't think you can see that place during operation unless you have the rear cover off and know just how and where to look down the tube of the motor head. The second place is at the rear of the machine at the copper contacts on the speed control switch. You can see in the machine during operation at this location. You should not be overly concerned about this...unless...you are seeing constant arcing, then you need a new speed control switch as the resistance (amount of metal to conduct the electric current) between the contacts is worn down. This will cause a constant arc and will eventually wear down and then freeze closed and ...Walla! the mixer will not work any more and it can short out the rest of the electrical in the mixer. So; if you are seeing short intermittent sparks at the rear of the machine , well no worries, if it is constant then replace the speed control switch if it is anywhere else it is an electrical short and that can be very dangerous indeed. Tell us where you are seeing the sparks...and we can FixYa.
KitchenAid... | Answered on Sep 15, 2018
The gearbox grease has separated and is starting to move (slowly) onto the motor armature area through the front bearing. Replace the grease and since it will be apart, use a lot of cloth strips (NO Q-TIPS! TOO STRINGY - LEAVES A MESS) and alcohol to clean off the motor's armature, housing area and any place you see grease slung around. It's not going to be easy, but worth it. I will try to post pictures as I am doing this right now 12/28/17 to my wife's Kitchenaid for this exact reason.The first image is the gear side of the motor bearing, where the thinning grease is moving through. The second image is a shot of the armature of the motor where the brushes touch and will smoke if grease gets that far (it does). The third image is a cleaned out armature area (brushes removed and speed switch moved)The last is the pooled oil separated and sitting just behind the gear box (where will it go if you tilt the head back?)07667273-29b4-4c89-b9b3-12896c8ef14c.jpg20171228_163751-wafg2nvpw021bpnzetjjpo05-2-2.jpg20171228_165900-wafg2nvpw021bpnzetjjpo05-2-3.jpg20171228_173846-wafg2nvpw021bpnzetjjpo05-2-4.jpg
KitchenAid... | Answered on Dec 28, 2017
Ideally you need to fix what's bent and that normally would involve splitting the cases to get at and repair or change the speed control lever. If you don't want to do that then removing the back cover and altering the adjustments and maybe bending the switch contacts may make it operate at both ends of the speed control.
KitchenAid... | Answered on Nov 30, 2017
-Check under the unit to see how many volt it required to run.
Some model require to run 220 volts.
Good luck
Mai
KitchenAid... | Answered on Nov 27, 2017
The head height adjustment screw is visible from the front when the head is raised. Looking from the front it is right at the back where the machine head hinges on thew pedestal. Clockwise to lower and anti clockwise to raise the head. You want it as low as possible without the flat paddle tinging on the bowl when the motor is running. Kitchen aid also make a paddle with rubber edges, called a scraper paddle. That one wipes against the bowl during operation.
KitchenAid... | Answered on Nov 13, 2017
Aussie helpline
1800-990-990
KitchenAid... | Answered on Jul 25, 2017
By pass the switch and put it on power strip and turn on/off with strip. Or just replace the ****** switch. Or just bypass switch and plug and unplug to turn on and off.
KitchenAid... | Answered on Jun 15, 2017
Hello Wittwer,
I understand that you are having a problem with your head locking in the down position. This is a common problem when the set screw that holds the latch in place is missing. On the right side of the base up next to where the lock is you will notice a whole that has threads make sure that the set screw is there if not you will need to order a new one. Here is a link to sears parts direct where you can purchase a new set screw they cost $4.62.
Thank you for choosing FixYa.com
Justinbur167
KitchenAid... | Answered on Mar 17, 2017
Sounds as if the problem is with the assembly and/or the adjustment of the control plate. The Service Manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
KitchenAid... | Answered on Oct 02, 2016
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
457 questions posted
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
successfully got thevpaddle off but
  • Food Mixers
