The 88 in the display most likely means you have a stuck or shorted keypad.
If the control senses a keypad pressed for more than 75 seconds then it will display an 8 error. There is a membrane/interface test that you can enter and run if you don't mind a little do-it-yourself. The image below will show you how to enter and run the membrane test. If you can not enter the test or some keypads are not responsive then you will need to replace the console/membrane. You can obtain the console from this link.
