20 Most Recent Samsung RF265AA Bottom Freezer French Door Refrigerator Questions & Answers
owls hoot, pigeons and doves coo.someone is playing a trick on you with a fake bird
Samsung RF265AA... | Answered on May 13, 2019
That sounds like a power glitch. Try pressing and holding the power freeze and power cool buttons at the same time for about 8 to 13 seconds and see if it clears.
If that doesn't do it, let me know and I'll dig up the Fast Track on it.
Samsung RF265AA... | Answered on Feb 04, 2019
My samsung rf265ab did the same thing after I was cleaning it and the door was open for an extended time. I noticed the the light bulbs looked good and also notice 2 tiny black buttons between the light bulbs. They were slightly extended. I pushed both in and when I opened the fridge again the lights were working. Don't know if I fixed it or just a coincidence.
Samsung RF265AA... | Answered on Dec 12, 2018
http://downloadcenter.samsung.com/content/UM/200802/20080205162030328_DA68-01632A_EN_V0.3.pdf
bad temperature sensor?
i suggest posing your inquiry direct to Samsung Support Staff
800-SAMSUNG (800-726-7864)
www.samsung.com
Samsung Electronics America, Inc.
400 Valley Road Suite 201
Mt. Arlington, NJ 07956
Samsung RF265AA... | Answered on Sep 28, 2018
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Samsung RF265AA... | Answered on Jan 27, 2018
Is it getting water? If not, Most likely water valve is faulty and not letting water through, or feed tube through back freezer wall to ice maker is frozen which would be caused by dripping valve. It's either the valve or the ice maker not sending voltage to valve.
Samsung RF265AA... | Answered on Nov 12, 2017
Your settings should be -5 to -10 in freezer and +37 in the fresh food compartment. This will keep the unit from running too long and your floor temp to be normal..
Consult your users manual!
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Samsung RF265AA... | Answered on Oct 16, 2017
Wait a few hours before you jump to conclusions. All depends on the position of the cam.
Samsung RF265AA... | Answered on Aug 23, 2017
the front supports are threaded to allow for the adjustment and levelling
while you want the appearance to be in line with everything else, the next complaint will be that it is not cooling properly or the door will not close properly
unfortunately fridges do not come with a self closing door and people are forgetful and that is why it is best to have a slight slope to compensate for forgetful people and yes it is good old cheap gravity
Samsung RF265AA... | Answered on Aug 06, 2017
Best way is DO NOT use the spring.Use a common elastic at the bottom of the folding flap run around the flap to a short small screww you would drill into the plastic under the door.This lasts longer than the spring and when it gets tired,just replace with another elastic,lasts for years and works better.
Samsung RF265AA... | Answered on Jul 25, 2017
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Samsung RF265AA... | Answered on Jul 24, 2017
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
699 questions posted
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
samsung refrigerator 33e code flashing
  • Refrigerators
