20 Most Recent Hitachi 53UDX10B 53" Rear Projection Television Questions & Answers
0answers
Problems with Hitachi Ultravision 53UDX10BA rear projection television!!!!!!!
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size
1/12/2018 8:21:10 AM • Hitachi 53UDX10B... • Answered on Jan 12, 2018
My tv has double picture how do i fix it
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With any Projection Television that has a damaged convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
10/3/2017 5:45:47 PM • Hitachi 53UDX10B... • Answered on Oct 03, 2017
2answers
Philips 42PF7321D/37 plasma 42 hdtv
flashing 4 times in 3 second
12/9/2016 11:50:27 PM • Hitachi 53UDX10B... • Answered on Dec 09, 2016
Wireless headphones not working after setting hitachi 53udx10b to factory default settings
Check the manual for instructions on resetting the parameters.
6/8/2015 5:57:54 PM • Hitachi 53UDX10B... • Answered on Jun 08, 2015
Tv screen does not come on and there is a high pitched "whine" from the rear of the TV
That is a 400 dollar part and it has to be special ordered.
3/13/2015 3:24:38 PM • Hitachi 53UDX10B... • Answered on Mar 13, 2015
2answers
Removing the JK07132-A convergence board
Unplug TV from ac outlet for few hours, this will discharge caps in circuit boards and you can take out desired board after unplugging connectors.
Always Be Careful while doing repair in TV.
3/6/2015 5:47:52 PM • Hitachi 53UDX10B... • Answered on Mar 06, 2015
Hitachi ultravision rear progection converge
If the convergence is so far out that you cannot adjust with your customer access menu then You will probably need the convergence ICs replaced & possibly a fuse or resistor or 2. Then a complete convergence will be necessary & I HIGHLY recommend having a professional technician perform this task.
6/5/2014 4:01:27 AM • Hitachi 53UDX10B... • Answered on Jun 05, 2014
Hitachi ultravision reset converg
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/ Convergence adjustment details are given by one of its posts.
5/23/2014 3:11:42 AM • Hitachi 53UDX10B... • Answered on May 23, 2014
I have a hitachi ultravision and it has green lines
Try contacting manufacturer and tell them what is happening, they may have an easy answer. If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
5/23/2014 2:09:51 AM • Hitachi 53UDX10B... • Answered on May 23, 2014
Hitachi 53UDX10B 53" Rear Projection Television Logo
690 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
am seeing blue shadows screen while
  • Televison & Video
