Lexar FireFly 1GB USB 2.0 JumpDrive - Blue Logo
Posted on Dec 04, 2010
Lexar jumpdrive firefly 16GB I've deleted all files off of this thumb drive, it is now empty, however, all the memory is taken still. I can't put new things on the thumbdrive as a result.
jameskory
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 20, 2015
jameskory
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
622
Points
7
Yes, it is possible to recover your files from lexar jumpdrive. see this step by step guide
Recover deleted formatted files from Lexar usb drive
you can use it to undelete your files from lexar jumpdrive.
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
6247
Points
16
First of all try a data recovery program such as Wondershare Data Recovery to get the deleted files back. Get the program here,
Data Recovery Windows (for Windows OS)
Data Recovery Mac (for Apple Mac OS)
Then format the pen drive from Disk Management if you are running Windows.
Remember - Do NOT try & write anything back to your pen drive until you can recover your data safely!
HOW DO i USE THE 16GB FLASHDRIVE?
Insert the drive into a USB port on your computer. Then it'll become a drive you can see in My Computer. After you see the drive you can copy files to it like any folder on your system. You may even create folders and child-folders on your USB drive to keep things organized.
I have a jumpdrive4usbgb. I want to transfer a file from my desktop pc to my new laptop pc. how do I do this?
insert the jumpdrive in your desktop pc and copy the contents from the pc to the jumpdrive... then insert the jumpdrive into the laptop pc and then copy the contents from the jumpdrive and paste it in your laptop pc at the specified place..
1helpful
Storage issue LEXAR Firefly 4GB
Empty your "Recycle Bin", to permanently detect some "hidden" files on the JumpDrive.
If necessary, try a "quick-Format" to reformat the drive, deleting all "hidden" files.
2helpful
I deleted all the viewable files and folders on my lexar firefly jumpdrive, but it says that i still have almost all my memory used up. how can I clear it?
You may have hidden or locked files. If the files are locked, you'll see an icon to unlock them when you open the JumpDrive in Windows Explorer. If the files are hidden, try and show them: Tools-->Folder Options-->View--> Left Click "show hidden files and folders" Good Luck!
I dont know how to save a writing piece from the word pad onto the lexar firefly
Open Wordpad, click File-->Save As; type in your desired name for the file and click the pull down arrow near "Save in:". Select the appropriate Drive (G/D,E or whatever) that is your Firefly. Click save. The file should now be saved as a Rich Text Formatted document on your Firefly. You can save it as a Text Document as well under the "Save as type:" option. Good Luck!
2answers
I have a Microsoft Excel file saved on a thumb drive that won't open. All the others will. I get, "file format is invalid"
It may be that excel file saved on your thumb drive is in .xlsx format(Office 2007) which you are trying to open on a machine which doesnt have office 2007 rather it may have Office 2003 or lower vesion.
Check this and hope it helps !!
Awaiting response.
Thanks !
2answers
Hi there, I'm having problems opening the files on Lexar 2GB JumpDrive FireFly it just says not formatted do you want to format? Please help I have precious photos etc. Thanks
If it says that the files are probably gone, sorry. Try using it on a different system, if it says the same thing they are definitely gone. Good luck I hope it works on a different system.
Please show me step by step on using the Lexar 2GB JumpDrive FireFly flash drive. I have an HP computer. I need to back up many photos. I will buy more of the same flash drives if I learn how to use them....
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
1helpful
Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Top Lexar Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
