20 Most Recent
Lexar FireFly 1GB USB 2.0 JumpDrive - Blue Questions & Answers
My 16 GB Flash Drive won't function properly
The H2TestW test program gives failures. That means that there are serius errors. Which errors does H2TestW give?
Try to reformat the FlashDrive. If that fails too, the drive is faulty and should be replaced.
HOW DO i USE THE 16GB FLASHDRIVE?
Insert the drive into a USB port on your computer. Then it'll become a drive you can see in My Computer. After you see the drive you can copy files to it like any folder on your system. You may even create folders and child-folders on your USB drive to keep things organized.
I Have used one befor
When you put the usb connector end in a usb slot on your pc or laptop wait a few seconds and there will be a new drive letter. That will be your USB drive. Format it if you need to otherwise you can put pictures, video , music or any other fike you want to put on it.
Usb flash not working
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
I dont know how to save a writing piece
Open Wordpad, click File-->Save As; type in your desired name for the file and click the pull down arrow near "Save in:". Select the appropriate Drive (G/D,E or whatever) that is your Firefly. Click save. The file should now be saved as a Rich Text Formatted document on your Firefly. You can save it as a Text Document as well under the "Save as type:" option. Good Luck!
I deleted all the viewable files and folders on my
You may have hidden or locked files. If the files are locked, you'll see an icon to unlock them when you open the JumpDrive in Windows Explorer. If the files are hidden, try and show them: Tools-->Folder Options-->View--> Left Click "show hidden files and folders" Good Luck!
Flash drive repair
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
How to remove write protected in Lexar 4GB
You may need Administrator privileges on your computer.
Plug in flash-drive.
Allow time for Windows Explorer to read it.
Run AV scan if suspect.
To get a list of attributes:
Launch Start > Run > CMD.
From the command console enter
attrib F:
(or whatever the drive letter is for your flash).
to redirect output to a text file enter (example)
attrib f:>%homepath%\flashatb.txt
From the list you should see [H]idden, [S]ystem or [R]ead only attributes for write-protected files.
You can also do it via Win Explorer by right-clicking the drive icon.
Remove all above attributes.
As a last resort, you can full-format the entire flash via explorer.
Which should wipe all files / folders on the drive.
7/5/2018 3:14:42 AM •
Lexar...
Answered
on Jul 05, 2018
HOW TO UNLOCK LEXAR MERMORY CARD
There is a little tab on that unit that slides back and forth. If the tab is missing, you need to use a piece of scotch tape to simulate the tab.
2/10/2017 2:10:34 PM •
Lexar...
Answered
on Feb 10, 2017
Lexar hi-speed 16GB stix, I NEED DIRECTIONS TO TRANSFER FROM COMPUTER TO STIX
plug the flash drive into a usb port
it will register on the desktop and will be recognized in the computer
and given a designation--- example:- drive h---
select what you want and save as --in h
or copy /paste to h
or if you have 2 screens click and drag to h in the computer section of the second screen
10/2/2016 9:08:58 PM •
Lexar...
Answered
on Oct 02, 2016
