Bose Wave Radio Logo
Posted on Dec 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clock in 24 hour mode how do I change to 12 hour time mode
Anonymous
Level 2:
New Friend:
  • Expert 52 Answers
  • Posted on Dec 04, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
52
Questions
0
Helped
10179
Points
169
On first generation Bose, press "Alarm Setup" and "on/off" button to toggle between military and 12 our time.
Older model documentation:
http://www.bose.com/pdf/customer_service/owners/og_wrcd.pdf
How do i reset the 24-hour time to 12-hour time on a Brookstone alarm clock
Dozens of models to choose from. All questions on Fixya need 'make model (what it is)' as the first 3 words.
Here are some guesses. The 'control cover' is where you put the back-up battery.
To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format .
Self-Setting Clock - Brookstone
Instruction Manual - Brookstone
Brookstone https://manuals.brookstone.com > ... PDF 12/24 HOURS TIME DISPLAY SETTING 1. The "12h" or "24h" will start flashing in LCD2 (Default setting 12h). People also ask
How do you convert a 24-hour clock to a 12-hour clock?"); display: inline-block; height: 24px; width: 24px;"> How do I change my alarm clock to 24-hour clock?"); display: inline-block; height: 24px; width: 24px;"> What is 12.30 pm in 24-hour time?"); display: inline-block; height: 24px; width: 24px;"> Feedback
Setting The 12/24 Time Format; Setting The Daylight Savings ...
ManualsLib https://www.manualslib.com > ... > User manual
Brookstone TIMESMART Self-Setting Clock Radio Manual Online: setting the 12/24 time format, Setting The Daylight Savings Time. The 12 Hour Format Is Set As ...
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
2answers
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
12helpful
I don't know how to set my clock on my 2006 uplander
Hello, here is the instructions for setting your clock on this vehicle.
Press the H or the M button to enter the clock mode. Press and hold H until the correct hour appears on the display. Press and hold M until the correct minute appears on the display.
To change the time default setting from 12 hour to 24 hour, press either the H or the M button to enter the clock mode. Press the tune knob to select between the 12 or 24 hour display format. The clock mode automatically times out with the changed display format set as the current default setting.
Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
Dec 06, 2010 • Watches
2answers
My microwave clock is set in 24 hour mode and I don't know how to change it to the 12 hour mode
Depending on the brand, if you push the clock button more than once it changes from am to pm to military time (24 hour) to am, to pm, etc.
11helpful
2answers
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
1helpful
2answers
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
Clock format
24 hour mode is all there is. Time to learn military time.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
