SOURCE: Wireless security not working on my D-Link DIR-655
- Log on to the configuration page of the router
- Go to Manual Wireless Network Setup
- And Change the Channel width to different one
SOURCE: Roku player not finding Netflix server. D-Link 625 router
Is the firewall on the router set up to allow the netflix? Are you having trouble with other applications on the Internet?
SOURCE: laptop doesn't recognize printer[c-7280]
For wireless security you can select WEP or WPA security. Some are specific lengths but within reason you can choose your own. Set in on the router first then on the computer. You may need to set up the router with a wired connection
SOURCE: I have a D-Link router
Log onto the router(if you dont know how, google your router for the default log in details) If these have been changed, reset the router.
go to wifi security.
Choose WPA2 if possible, you choose the password.
If you can only use WEP(very weak) it gives you a long passkey
SOURCE: I want activate the WEP,WPA, OR WPA2 i DONT
Step 1 Log into the web configuration of the router by opening up
a web browser and typing in the IP address of the router (192.168.0.1).
Click here if you cannot access the web-based configuration.
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
Step 4 Select Key 1. Enter a Hex encryption key that you
make up. The length of the encryption key will depend on what you
selected under WEP Encryption.
The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
Step 5 Click on the Apply button then click on the Continue button to save your settings.
Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
Note: Not all D-Link routers, print servers and access points
have a web-based configuration utility. Please check the manual for your
particular product. In particular, the DWL-900AP does not have a web
utility while the DWL-900AP+ does have a web utility. You cannot gain
web-based configuration utility functionality for the DWL-900AP by
installing the DWL900AP+ utility.
When entering the IP address of the D-Link device (192.168.0.1 for example), you are not connecting to a website on the Internet
or have to be connected to the Internet. The device has the utility
built-in to a ROM chip in the device itself. Your computer must be on
the same IP subnet to connect to the web-based utility.
