Hotpoint REM25SJ Microwave Oven Logo
Anonymous Posted on Dec 03, 2010
I have a Hotpoint microwave oven model REM25SJ that won't heat and you hear no noise. The display says "cook time" and the timer counts down. In addition, the internal cabinet light comes on but the turntable does not rotate.
  • 1 more comment
  • Anonymous Dec 03, 2010
    I assume that a bad magnetron could also generate no noise. How would you test for a bad magnetron?
  • Anonymous Dec 06, 2010
    Thanks for your information. It gave me the confidence to attempt a repair of the microwave. When I took the cover off I found an envelope that contained a wiring diagram, electrical schematic and troubleshooting logic diagram. These documents were very useful for troubleshooting. The problem was a bad spade connection on the Primary Switch (upper). The connection must not have been tight because the male spade connector on the switch had tiny metal bumps from arcing. The plastic cover over the female connector was darken by the arcing. After cleaning the spade connector and tightening the female connector the microwave is now working again. Thanks for your help.
    The information provided gave me the confidence to undertake the repair of my microwave. My problem was a bad connector on the Primary Switch, which was one of the possible causes identified by the expert.
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on Dec 03, 2010
Master
Level 3:
Answers
6993
Questions
Helped
1701420
Points
1261
A microwave not heating up is caused by one or more of the following -
1) Failed controller board (unlikely if you are getting a clock readout and you can get the various functions to work, just no heat)
2) Failed door switch
3) Failed thermal fuse, when used
4) Blown power fuse that is dedicated to the microwave circuit
5) Bad diode
6) Bad capacitor
7) Bad magnetron
8) Bad transformer
Door switches insure the microwave circuit will not engage when the door is open. Slamming the door of the microwave is hard on the switch.
The thermal due is wired into the microwave harness, and is a melting allow type, based on heat buildup within the oven. Always replace with a fuse of the same thermal rating.
The power fuse is a special type and should only be replaced with that same type and rating. It is easily tested.
The diode is a relatively inexpensive part, and is not easily tested. If a grumble is heard coming from electrical area of the unit, then the diode could be shorted.
A shorted capacitor will blow the fuse immediately. And open capacitor will cause a "no heat" condition.
A bad magnetron will also cause a low level hum or grumble from the transformer. But is may also cause no other identifiable symptom of failure.
A bad transformer will exhibit a grumble or hum, and may or may not blow the fuse. But be careful here, the secondary of the transformer produces very high voltages, up to 2.5Kv. Few people own a meter capable of measuring such voltages.
Service and repair of microwave ovens is dangerous work. If you don't know what your doing, DO NOT ATTEMPT TO SERVICE A UNIT WITHOUT INSTRUCTION.
I hope this helps.
Good luck.
  • Wale Sarumi KomputerSolution
    Testing a magnetron
    NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
    There
    are two tests to conduct in order to determine whether or not a
    magnetron has become defective. If you receive results other than what
    are detailed below, you will have to replace your microwave's magnetron.
    Each test is described for you here:
    TEST 1: Locate your
    magnetron and label each of the wires attached to it so that you know
    which wires are to be replaced where. Set your ohmmeter to the lowest
    resistance scale. Take a resistance measurement between each of the
    magnetron's terminals by touching each probe to one terminal each.
    Reverse the probes and take a second resistance measurement. Each
    measurement should read less than one ohm.
    TEST 2: Set your
    ohmmeter to its highest resistance scale. Touch one of the meter's
    probes to a magnetron terminal. Touch the other probe to the metal
    magnetron housing. Take special caution to not touch the two probes
    together. This could result in an inaccurate reading. This test should
    produce a reading of infinity - indicating an open circuit.
    Good luck again.
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
2helpful
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Microwave timer works, light works, but heating mechanism will not engage-- no "sound" or "heating" when I hit start (although the timer mechanism sets & counts down, even when...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
The fan in the microwave is making a very loud noise? Can the fan be replaced?
I woud advise scrapping as microwaves are rarely worth repair - I am an approved appliance tester and annually fail 10% for dangerious emmision levels
1helpful
It makes a groaning noise and does not heat up. There is a burnt area on the top, middle, right hand side.
You may have a shorted high voltage diode, but I would suspect that you also have a failed magnetron, and with the burns you mention, the waveguide of the oven is possibly damaged, which is unrepairable.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
That bulletin has a picture of a burned waveguide.
1helpful
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
3answers
I have a new job and I am here alone. There is a
the magnatron has gone bad and needs to be replaced
Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
GE Microwave Model # JE1860: Unit does not heat. The timer counts down, but the oven does not heat.
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Top Hotpoint Microwave Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
