20 Most Recent Hotpoint RVM1325WW Microwave Oven Questions & Answers
On most GE/Hotpoint models, the control panel assembly will either tip down, or pivot sideways for access to the components behind it. Screws holding the top air deflector might have to be removed in order to gain access to the control panel mounting screws. I recently junked-out a similar model. The main fuse was near where the power cord enters the cabinet on top. Avoid contact with any of the high voltage components.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Hotpoint... | Answered on May 10, 2014
F3 or F4
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Keep us updated.
Hotpoint... | Answered on Jul 10, 2011
You can download the owners manual in PDF format from the manufacturer's website by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Hotpoint... | Answered on Jul 06, 2010
You have a faulty display module due to one or more components leaking. Some models have a seperate display module that can replaced without the complete board having to be replaced. If not, the board needs to be replaced. You need to ask your spares suppliers that have info. on that model.
Hotpoint... | Answered on May 21, 2010
if the microwave is humming there is a fult in the megnatron,,
(thats the part that heats the food) there very pricy to buy and its not a good idear for you your self to try to fit a new one,,,as in side the microwave is a very big capasitor,, it works much like a police stun gun but it wont just stun you it could kill you if you tuch the wrong part,,,
bets thing to do it drop it into a shop for this fix or to be realy honest microwaves are so cheap now it would be a far better bet to go out and buy a nice new one, its not worth throwing good money at an old microwave only to have it pack up in a fuw more months
Hotpoint... | Answered on Mar 14, 2010
your high voltage circuit is out. might be ur transformer
Hotpoint... | Answered on Feb 12, 2010
the kliestron is most likely bad or the stertup solenoid is stuck. also could be the control module needs replaced...
Hotpoint... | Answered on Nov 12, 2009
depending on the age of the unit i would replace it
the most common issue for this call is the hv transformer and magnetron or diode, any one of these could be bad and making the other ones go bad
mic's are tough to call which is bad in person, i would be even harder pressed to nail it down other than one of those three or all of them
for the cost id just replace it
Hotpoint... | Answered on Oct 22, 2009
Hotpoint RVM1325WW Microwave Oven Logo
27 questions posted
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Gerry Harvey
Gerry Harvey
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Microwave Ovens
Most Popular Question
makes hum sound amp doesnt heat
  • Microwave Ovens
