20 Most Recent
Hotpoint RVM1635 Microwave Oven Questions & Answers
No power at unit. Power to plug
Jim, Take the screws out that hold the cover on your unit and then take the cover off. Find where your cord goes into the machine and follow the black wire from the cord, it normally should go to a small circuit board and your fuse is usually mounted on that circuit board. It will be a 15 amp fuse and you usually can get one of those at most appliance parts stores. If there is not a circuit board the black wire may go directly to an in-line fuse holder. Hope this helps.
Microwave range hood install -- stud in middle of exhaust
You have a few options, First off, I am assuming that the stud you refer to is an outside wall. Assuming that is true, then you have a few options.... one of them is to cut thru the stud and run the vent out. Even if that stud is on a bearing wall ( meaning it is carrying a roof load above it) ... It is unlikely to pose a problem if that one stud has been compromised with it cut out, If that concerns you.. and you are handy, you can open that area of wall up from the inside and box the area that the vent will be located in with short pieces of 2x4 to the studs on either side of it... Another option is to vent the hood up thru the cabinet above and direct that out slightly offset to the stud in the wall..
One thing I have done is to cut the stud out and then to place a piece of 1/2" plywood in the area that the micro/hood will be located and attach that piece with drywall screws to the studs in the wall.. That piece of plywood will help support the stud you cut when you screw it to the adjacent studs and also act as a place to secure the hood mounting bracket on the wall. Granted, it shifts the hood out from the wall 1/2 " but then you have plenty of surface to secure the plate and don't have to worry about hitting a stud or using wall anchors.. I hope you understand my comments..If not...please respond to this and I will provide additional information to clarify this... Hope this helps !
Rvm1335bc001
sounds like the control board, but most times the magnetron fails and if a fuse failed then it needs a capacitor too
How do i change the fuse in the hotpoint rvm1635
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
http://tinyurl.com/gv383
In this case, they have the RVM1625, and it may be close enough.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Turntable not rotating
Most likely the gear is stripped. Pull up the turntable and then run it. Watch the wheel and see if it is spinning without the turntable.
Fuse keeps blowing in hotpoint microwave
The magnetron is the other issue, high voltage diode will sometimes crack causing a high level short, the capacitor developes a dead short across the 2 points, the power transformer almost never fails, "very rare"
Paint on stove
You can use paint removers which are available with any paint shop, Normally THINNER or even turpentine will be good , try also with kerosene which is mild and will not remove too much of the inner coat.
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Beneath the time on the clock. The word "mute"
I have 2 possible solutions for you.
1) press and hold the 0 button for 3 seconds. This may only turn the clock display on or off, but may also mute or unmute the beeps.
2) unplug the unit for 30 seconds to a minute. Plug it back in and it should be reset.
No power to oven. Receptacle it is plugged into
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
My micrwave oven continues to
The problem may be a defective door switch, or the door is out of alignment, or you have a short in the keypad control. This should be looked at right away because it is exposing you to radiation hazard. I highly recommend appliance technician check the unit asap.
F3 kEEPS COMING ON
Hello &
Welcome to FixYa
F3 error in
your unit means shorted key panel (touch pad assembly) and is displayed when a
shorted key panel is detected continuously over 60 seconds. Try to blow some
air on the touch pad assembly, if this won't work then replacing the keypad is
recommended repair. Please get back to me if you have any other questions.
Kevin
Panel doesnt work reads pf
Hi
PF means power failure, to resolve this issue take a hair
dryer and with the unit unplugged and the control apart blow air on the
electronic part of the control. If the issue returns then the control board
should be replaced. Hope this helps...
Daniel
Lights and fan quit working
there are fuses inside the microwave but there not the kind you would have in the house,,unless you can buy them it cant be fixed by you,
