20 Most Recent Hotpoint RVM1535MMSA Microwave Oven Questions & Answers
Microwave keeps turning on by itself, as if a key
unplug your microwave for a few min. plug back in.
3/2/2011 1:42:53 AM • Hotpoint... • Answered on Mar 02, 2011
Microwave timer works, light works, but heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
2/25/2011 3:41:08 PM • Hotpoint... • Answered on Feb 25, 2011
It is not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kgkjf
9/30/2010 2:17:32 PM • Hotpoint... • Answered on Sep 30, 2010
No power
Depending on the brand and full model number, it may.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download many brands' mini-manuals here.
Sometimes the problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with aone year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
7/11/2010 3:51:17 AM • Hotpoint... • Answered on Jul 11, 2010
2answers
Brand new Hotpoint Microwave doesn't heat
Brought microwave back to store. It didn't appear to be something I would be capable of fixing myself.
Got a new one which is working fine.
5/26/2009 4:56:31 PM • Hotpoint... • Answered on May 26, 2009
2answers
Microwave safe glue? Is there one I could buy
google your Hotpoint model number include parts, Dowsil is approved but is price prohibitive.
3/18/2024 4:55:59 PM • Hotpoint... • Answered on Mar 18, 2024
MD344IXH Hotpoint microwave keeps stopping and beeping when not in use
Could be a faulty control knob.
12/21/2023 7:25:34 AM • Hotpoint... • Answered on Dec 21, 2023
My Hotpoint MN3141XH microwave ovens plastic film/guard on the inside of the door is coming away
Yes you do indeed need a new door. The door is a complete safety unit and access to the microwave.
6/22/2023 5:23:09 AM • Hotpoint... • Answered on Jun 22, 2023
My Hotpoint microwave oven cuts off after 3 mins. The fan wasn’t working so I replaced the fan motor . Now th3 fan is working the microwave still cuts . Please help
There is a chip that controls TOTAL operation of the microwave, sounds like it malfunctioned. It actually sound like the entire board has malfunctioned. good luck https://www.6ya.com/mrmmike
3/2/2019 7:48:50 PM • Hotpoint... • Answered on Mar 02, 2019
Hotpoint Microwave Model RVM1435BD 001- microwave comes on when I open the door.
Many microwaves have similar issues. Usually, (not always) only the light is on and the fan is running, not the section that produces the microwaves. This problem can be caused by the door switches that are out of alignment or a defective control board.
11/15/2017 7:12:12 PM • Hotpoint... • Answered on Nov 15, 2017
Sears sent me a diode for hotpoint microwave and a video for replacement and the video is different. Can't find the diode for MY Hotpoint rvm1435bk01 to see if it's the same to replace.
Most microwave diodes will work just fine from system to system. The most common ones I use are rated at 550ma. When you check your old diode what made you think it was bad? They are such a high rating you will not get a reading on it with a regular ohm meter. Mostly on HV rectifiers if it is not shorted ( Zero Ohms) it is probably good. If you have no high voltage then substitute it and see if you do get high voltage, then you know it was open. Follow the video and give it a try.
8/24/2017 9:16:47 PM • Hotpoint... • Answered on Aug 24, 2017
My hotpoint microwave beeps and the display says -F3-
"F3" means you have a shorting membrane keypad. I regularly repair these controllers and details are here. If you have other questions, it's best to follow up with me directly. (FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.) - William E. Miller, AS-EET [email protected] http://www.microwavecontrol.com Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
5/25/2017 1:55:05 AM • Hotpoint... • Answered on May 25, 2017
Hotpoint microwave model RMV1435BD under recall??
None to my knowledge, but common faults include keypad failure (may show error code "F3") and cooktop light failure, both of which can be affordably repaired. (See link below) For more free DIY and other help & advice, feel free to contact me via my site below. Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back) William E. Miller, AS-EET http://www.microwavecontrol.com Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
2/17/2017 8:05:00 PM • Hotpoint... • Answered on Feb 17, 2017
How can I get a copy of the manufacturer's installation instructions for a Hotpoint JX-81J over the range microwave oven?
JX-81J is the microwave recirculating charcoal filter for several models of GE and Hotpoint microwaves. The installation instructions will be available from the manufacturer with the model number of the microwave itself. One microwave that uses this filter is the RVM1535MMSA . See http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=HPSPECPAGE&Sku=RVM1535MMSA#tab1_ for all of the details on this microwave. The owner's manual, http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40541-1.pdf , shows the installation of the filter on page 34. The guide for installing the microwave above the range is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40425.pdf . If you have a different microwave, add a comment with that model number. I hope this helps. Cindy Wells
2/14/2017 3:32:39 AM • Hotpoint... • Answered on Feb 14, 2017
Hotpoint RVM1535MMSA Microwave Oven Logo
23 questions posted
Top Hotpoint Microwave Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Microwave Ovens
Most Popular Question
microwave keeps turning itself as key
  • Microwave Ovens
