Sometimes it is the software there (the firmware) needs to be updated so the charging will be fixed. You can go to their web site to check and download the updater software. Otherwise you may try to use a outside charger other than your phone to charge the battery or charge the battery at the store to see whether the battery is working.
Did you try to crack it open with a little knife or a screwdriver in seams or is there a clip or something you can press on the surface?
You can see how the parts look like on the following page.
http://www.cellulardr.com/motorola-qa1-k...
How do I get the case off this phone? can find no screws at all on body. It is a slider phone. I need to get to the inside. T5 or7 is not working, tinier yet.
So how do I get the black plastic case off this phone???
Thanks
Not what I ask. I need to get the black plastic Mfg case off this phone to check the plug that the charger hooks into, plus I need to check and see if the inside is dirty.
There are two screws on the top slide where the screen is but that is all I can locate and that does not help me get tot the inside of this phone.
