20 Most Recent Hipstreet Flare 2 9 inch Tablet with 8GB Memory 2nd Generation and Portfolio Case Questions & Answers
IT KEEPS POWERING OFF
What keeps powering off?
8/18/2016 3:40:07 PM • Hipstreet Flare... • Answered on Aug 18, 2016
When i put the PowerPoint on i have only a9
Uninstall and reinstall app
6/24/2016 3:55:50 PM • Hipstreet Flare... • Answered on Jun 24, 2016
Can I buy a power cord that charges while you are using the tablet?
all tablets can charge while you are using them, on rare occasion the battery will completely discharge and will need to be charged to the minimum before operating the tablet.
3/13/2016 3:23:50 PM • Hipstreet Flare... • Answered on Mar 13, 2016
0answers
Tablet won't download anything says I have over 6 gigs but says 0 available space
Hi There. Firstly, from the sounds of things - The Tablet may be corrupt, as you are needing to go though the Setup process at each start up. However, before jumping to that conclusion - You may first want to clear up the Tablet. Copy all Music, Videos and Pictures to a different device and then clear it off of the tablet. Then uninstall all of the apps you longer require or do not need. Lastly, restart the Tablet and see what happens - If you need to do the setup process, then you will have to take it in for Troubleshooting and / or repair unfortunately.
1/13/2016 5:18:59 AM • Hipstreet Flare... • Answered on Jan 13, 2016
Is it possible to add bluetooth capacity to tablet
Hi I looked up the specs on you're tablet no mention of Bluetooth if it wasn't programed in at the factory u will have to do with out it ...cheers
8/4/2015 8:17:18 AM • Hipstreet Flare... • Answered on Aug 04, 2015
The screen is cracked? How do I get this repaired?
If it has warranty, you can return it though maybe they might object that crack is due tu incorrect manuipulaton of you tablet. Try it. In any case, the shop where you bought it should provide authorized repair service and they should have the spare screen. .
7/3/2015 2:25:55 AM • Hipstreet Flare... • Answered on Jul 03, 2015
0answers
0answers
Why app.com.google.process.gapps has stopped?
delete it and download it
4/15/2015 12:48:52 PM • Hipstreet Flare... • Answered on Apr 15, 2015
The event is frozen can you fix it
Desoler chantal mais je comprend pas ta question
4/12/2015 2:24:22 AM • Hipstreet Flare... • Answered on Apr 12, 2015
2answers
Not able to use the tablet.
Battery problem or charger maybe? If all else fails a factory reset is in order.
3/21/2015 9:47:34 PM • Hipstreet Flare... • Answered on Mar 21, 2015
My hipstreet flare opens Google news but when I tap any link it just opens a blank tab
You might try, instead of simply "clicking" a link, hold the link for a couple of seconds... This way, like right-clicking, you can not only choose to simply open the link, open it in a new tab, save it, etc., but you can also see what/where the link points to and decide from there if it's even a viable link! Let us know how it works out for you! Good luck! :-D
3/14/2015 4:48:46 AM • Hipstreet Flare... • Answered on Mar 14, 2015
Since a few days everytime I start up my Hipstreet Flare 2, I looses all my data. And I have to start all over again like if it was the first time I open it. I look at the settings and on "Backup and
You may not like this particular answer, and I hope you get a better one than I have, but that same thing happened to my Flare 2 & what I am doing, once I eventually got past the green android screen by continuously restarting, is keeping it charged & basically never turning it all the way off, only putting it into sleep mode. I've been told the internal memory chip is damaged somehow if the unit gets reset too many times... Like I said, I really hope you get a better answer than mine. Good luck, I mean it! Have an amazing day!!!
12/21/2014 2:09:18 PM • Hipstreet Flare... • Answered on Dec 21, 2014
How do i reset my flare 2 tablet
Geraldine, if holding Vol+ & Power button doesn't work, try Vol- & Power button...this worked for mine right out of the box, and now the plus works instead... Once you see the Android logo, let go. Then you can choose to reset the data first, THEN the factory settings... Let me know how it goes... Good luck & try to have fun!!!
11/24/2014 4:22:31 PM • Hipstreet Flare... • Answered on Nov 24, 2014
Hipstreet Flare 2 9 inch Tablet with 8GB Memory 2nd Generation and Portfolio Case Logo
Popular Tags
69 questions posted
Top Hipstreet Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Hipstreet Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Hipstreet Tablets & eReaders
Most Popular Question
screen cracked get repaired
  • Tablets & eReaders
