? 2:42
https://www.youtube.com/watch?v=gRqFYPyacCI
Sep 10, 2013 - Uploaded by Ivy Killa
This is what happen when i try to open my Hipstreet Flare 9" 8Go. ... All Comments (13) ... with a used tablet..in my opinion, if atablet cannot last longer than 2 months with the light ... did you try to factory reset it hold volume up and power, hold them until the menu pops up my just freezes when i try to reset it.Missing: letters l
? 5:17
https://www.youtube.com/watch?v=6MQSPJOVD4c
Jun 22, 2013 - Uploaded by RodneyDickson
WARNING - I will NOT be held responsible for any damages the ...Remove all; Disconnect ... shutdown on HipStreet logo screen when booting the Vektor tablet ... will show you how to solve the issue of your HipStreet Vektor 7 inch Deluxe ... How to fix android tablet hang-up, freezing & crashing problem ?Missing: letters l
? 3:27
https://www.youtube.com/watch?v=3Isu15ZoLls
Apr 28, 2014 - Uploaded by Lenz Walters
Hipstreet 9DTB7 - Flare Wont turn on (problem Solved) ... ThisHipstreet Flare 2 Google-certified tablet features a 9" LCD ...Capture every moment and video chat with those you love using the built in cameras. ... +Lynn L'Heureux no light at all ? .....com/2013/12/hipstreet-flare-9-inch-android-tablet.html or ...Missing: letters
It looks like an Android device. You can view and delete pictures by touching the *Photos* app. Touch the picture you want to delete and
depending on your Android Operating System version you will either see a little garbage can on the bottom right or have to touch the three vertical dot settings icon and choose the delete option from there. Touching the garbage can should initialize the delete process. You might have to confirm the delete before it gets deleted for good, in either case of operating systems.
If you want to wholesale delete photos and one at a time is too slow, you can usually connect your device to a laptop or desktop using the supplied USB cable and then you can use your computers file manager to select and delete as many photos at a time as you wish.
You have turn off the tablet, then hold Power and Volume+ for 10 seconds.
Then choose "wipe data/factory reset". Then choose "Yes - delete all user data" option. Then choose reboot option.
Google "screen replacement" . You will have many sites to choose from. Find one who has the part at a reasonable price. You may want to compare several sites for the best price.
If you cant get in on recovery mode there is little you can do - its hosed.
Take out any sdcard that may be in it and do a pin reset using the reset hole in the back of the tablet.
you might have played with settings
apply default setting
or else go to security and reset to factory setting
but prior to this restore your data and account
