Frigidaire ATF6000ES Front Load Washer Logo
Posted on Nov 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every time i put a load setting it shows the time when i press the start button it shows "dr"
Anonymous
Level 2:
  • Expert 130 Answers
  • Posted on Nov 30, 2010
Anonymous
Expert
Level 2:
Answers
130
Questions
0
Helped
45235
Points
733
You need to replace the door lock mechanism. It is pretty easy to replace, you can get the parts at http://www.reliableparts.com/ using your model number to look up parts. You just have to remove the spring around the gray door gasket to gain access to the door lock. Remove the screws holding it on, and instal new door lock, then re-install the door gasket and test the unit.
I have a JVC VCR/DVD-recorder, model DR-MV7S. It developed a problem... when you placed a DVD on the tray & pressed the "eject/open" button to take the DVD into the recorder, the tray...
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 • Televison & Video
tip
How do I set my iPod touch to tell me how long it will be Recharge?
<p>The iPod Touch, a portable media player from Apple, has an internal battery that will eventually run out of power while you reload. According to Apple, the iPod touch offers up to 40 hours of audio playback or up to seven hours of video playback when fully charged. The machine takes about two hours to recharge to 80 percent capacity, and about four hours to fully charge. Although the iPod Touch does not have an innate ability to tell you how long it will take to charge the battery today, you can create a free application that will give you an approximate time to load. <br /> <p>Preparation <br /> <p><br /> <p>1. Press the "Home" button below the touch screen of your iPod Touch. <br /> <p><br /> <p>2. Touch the "App Store" icon on the home screen. <br /> <p><br /> <p>3. Tap "Search" and enter a search term such as "Battery" and then "Search". Tap the name of an application results from the battery, such as "Battery Free HD", "Magic Battery" or "sense of battery Philips Consumer Lifestyle." Tap the word "free" next to the name of the application of the battery, and tap "Install. Tap your Apple ID at the prompt to download and install the application from the battery. <br /> <p><br /> <p>Battery Free HD <br /> <p>1. Press the "Home" button of your iPod Touch. <br /> <p><br /> <p>2. Touch the "Battery Free HD" icon on the home screen app to start it. A battery icon appears with the current level, and details about the estimated time to play music, videos and surf the Internet. <br /> <p><br /> <p>3. Touch the screen with your finger and drag it upwards to scroll to the "Time to Charge" song to reveal. <br /> <p><br /> <p>Battery Magic <br /> <p>1. Press the "Home" button of your iPod Touch. <br /> <p><br /> <p>2. Touch the "Magic Battery" icon on the home screen app to start it. A battery icon appears in a window below the current time available for various activities, such as "Play Game", "3D Game" and "Wi-Fi." <br /> <p><br /> <p>3. Touch the screen with your finger and drag to scroll the window until you see "loading time" with a number of how long it takes to load your iPod Touch. <br /> <p><br /> <p>Sense of the battery, Philips Consumer Lifestyle <br /> <p>1. Press the "Home" button of your iPod Touch. <br /> <p><br /> <p>2. Touch the "sense of the battery, Philips Consumer Lifestyle app icon on home screen to start it. The battery now appears as a percentage, with a grid above options for the different activities you can do with your iPod touch as" Audio playback "," Video Playback 'and' waiting time. " <br /> <p><br /> <p>3. Tap the "Time Charge" of the network. The amount of time it takes to fully charge your iPod Touch will show up under the grill. <br />
on Jul 21, 2011 • Computers & Internet
1helpful
The washer comes up "TEST" instead of the
Hello & Welcome to FixYa
Someone accidentally put it into TEST mode and to get it out of the test mode follow this:-- Unplug the washer for 4 minutes and then plug it back and press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Please get back to me if you have any other questions.
Kevin
When I press apostrophe quotes they don't appear. But when I press the button a second time, then I get double ( "" ) and have to backspace to get single quotations ( " ) How do I fix this?
Download the Microsoft settings utility for this keyboard and check through the options settings, especially for "smart quotes." The smart quote, if enabled, may not show up at either end of the quoted phrase until you press the apostrophe/quote key the second time; then both will show in their proper places, and one of the quote marks will be inverted (a nice style touch, if you want it).
5helpful
HOW TO LOAD THERMAL PAPER IN DR-T120 CALCULATOR
Simply place the paper between the plastic posts. Put top portion down; feed paper up slightly - put smaller front plate back in place and press feed button.
2helpful
4answers
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
13helpful
5answers
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
