DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
THERE IS ONLY ONE TUB GASKET IN THE MIDDLE BOTTOM OF THE TUBE ,TRY PUTTING IT ON SMALL LOAD AND SEE IF THE WATER STILL SPINS OUT,ALL YOU REALLY HAVE ON THE TOP IS A FILL SPOUT,ALL THE HOSES ARE ON THE BOTTOM RIGHT FRONT BEHIND THE FRONT PANEL,LET ME KNOW,THANKS-MIKE
it is leaking out the top ring seal,you will have to remove the top snap on around the top of tub and seal it with silicone and put the top ring back on,let me know-mike
SPIN RINSE CYCLE, it leaks on both sides in the back.
LEAKING UNDER IT
I set the washer to a smaller load and it did not leak, but why does it leak during rinse, not spin.
leaks while spinning
