20 Most Recent GE Profile Performance WPSF4170WAA Questions & Answers
My Ge washing machine is leaking from the Bottom
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
11/17/2023 2:59:32 PM • GE Profile... • Answered on Nov 17, 2023
0answers
2answers
Washing machine wont agitate
yes its belt.he is very correct.but many other possibilities check that also ----------- It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
2/19/2014 9:37:52 PM • GE Profile... • Answered on Feb 19, 2014
My Washer is NEW TODAY and is pouring water out of
a hose may be off
9/30/2010 2:03:57 AM • GE Profile... • Answered on Sep 30, 2010
My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
1/13/2010 2:12:39 PM • GE Profile... • Answered on Jan 13, 2010
Wont spin with heavy loads and is real load when
Suspect bad bearing(s) in drum support. May have a bad motor drive belt.
11/11/2009 10:11:34 PM • GE Profile... • Answered on Nov 11, 2009
Washer will not drain
I think you may be right about the pump is working to hard. May need to replace it.
11/10/2009 5:03:14 AM • GE Profile... • Answered on Nov 10, 2009
How do you remove the agitator in a top load GE
Pull off the center parts and remove the bolt you will see down inside the center.Then pull it off.
11/3/2009 11:05:20 PM • GE Profile... • Answered on Nov 03, 2009
Freezer has frost and build of ice
check and replace the defrost relay.
10/8/2009 3:45:32 AM • GE Profile... • Answered on Oct 08, 2009
Dishwasher isn't draining
this is usually caused by clogged drain it is the hose that leads to the water pump suction located in between the inner and the outer tub. you can usually feel around the hose by squeezing it if you feel a lump within the hose then all you have to do it remove the foreign material. you can do this by removing the top cover and reach over the bottom to try to remove it or by seperating the hose from underneath to clear the clogg.
9/18/2009 12:38:54 AM • GE Profile... • Answered on Sep 18, 2009
GE Profile washing machine leaks from the bottom .
There could be a screw on each bottom coner of the front panel. If not, take a putty knife (1 1/2" or 2"wide) Slide it between the lid and the front panel. You should fill a clip about 4" or 5" from corner. Pull putty knife out and then use it to push into each clip while pulling slightly on the front panel. Front will come off a corner at a time. From here you will be able to access everything.
You are most likely going to find that the plastic outer tub is cracked and all four round rubber straps located at the top of the tub broken. If so, you will be better off to replace machine because of the cost of a new outer tub and the labor required to replace it. If you chose to replace tub, you will need a tub wrench. The last one I bought was $68.00 15 years ago.
Please rate this solution
8/28/2009 3:45:38 AM • GE Profile... • Answered on Aug 28, 2009
WPSF5170W0WW G.E. Profile...Bout ta break something or someone
I had use dry ice to freeze the bolt so I could get off the nut...redicuolus...
Note: The pully is regular thread...Do not tighten this bolt down at all when you are putting it aside to wait for parts....I'm an @!#
5/25/2008 2:16:46 AM • GE Profile... • Answered on May 25, 2008
WPSF5170W0WW G.E. Profile Performance Washing Machine
most ge washers you just get ya fingers under the bottom and jerk up hard they have a plastic piece under them that has to be replaced from time to time its no big deal
1/18/2008 5:35:30 PM • GE Profile... • Answered on Jan 18, 2008
2answers
GE WSLP1100A0WW not agitating
It sounds like the clutch is slipping https://www.google.com/search?q=GE+WSLP1100A0WW+not+agitating
Top Load Washer - Fills But Will Not Agitate
GE Appliances https://products.geappliances.com > appliance > gea-sup... If the lid switch probe or magnet is missing or damaged, the washer will not agitate or spin, even with the lid closed. Missing: WSLP1100A0WW ‎' Show results with: WSLP1100A0WW
SOLVED: GE WSLP1100A0WW not agitating
Fixya https://www.fixya.com > ... > Washing Machines > GE 17 hours ago - Ge top loader washer agitator does not work To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator.
Ge Washing Machine - Washer Won't Spin Or Agitate
Repair Clinic https://www.repairclinic.com > RepairHelp > Ge-Washe... If a washer is not spinning or agitating, you should first determine if the drive motor is running and if power is reaching the drive motor. If no power if ... ..
4/21/2024 6:22:15 AM • GE Washing... • Answered 3 days ago
Can I get new brushes for my GE handmixer 56M17
No there’s no brushes for GE handmixer
3/10/2024 8:12:40 PM • GE Washing... • Answered on Mar 10, 2024
GE WASHER MODEL GFWH1200HOWW RUNNING EXTRAAA LONG ON WASH CYCLES??
Hello Heather Good to see you again. Also check the small strainers on the water connectors. They can block up with limescale and debris. While the connectors are off, turn on the water into a bucket or a sink. You should have a VERY powerful jet of water. Anything that will reduce flow will lengthen the fill time and therefore to total wash time due to fill and rinses. When it pumps out, also check you have good flow in the drain hose and items can jam in the ridges and catch lint enough to block them almost completely. One clever thing to do is whilst the water inlet connectors are off, unlock the drain hose, unhook the part that makes the hook, put the round connector in the hose and wrap a tea towel around it. Get someone to turn the water on full bore whilst you are gripping the two hoses together. Run it for a full minute. Water will be flushed into the machine through the pump in reverse. Put everything back and run a rinse and spin with nothing in it, look at all the black lint that is pumped out! I did that once at work and found an apple stalk that had lodged across the ridges of the drain hose which had 90% blocked the pipe. ..
2/23/2024 8:08:04 PM • GE Washing... • Answered on Feb 23, 2024
2answers
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
12/11/2023 6:33:13 PM • GE Washing... • Answered on Dec 11, 2023
2answers
GE Washing Machine model GTW330ASK0WW. It won't run, no sounds, display comes on and after 15 seconds shuts down.
Question edited for clarity 'MAKE model (WHAT IT IS)'. You posted to Televisions, moved to GE Washing Machine. It may be the lid lock, test it with your digital multimeter. Look for loose or damaged connections. https://www.google.com/search?q=GE+Gtw330ask0ww+not+running ..
10/21/2023 3:04:17 AM • GE Washing... • Answered on Oct 21, 2023
Washing Machines Logo
30 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
ge washing machine leaking from bottom
  • Washing Machines
