The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
