Proton MM2701VT 27" TV Logo
Posted on Jun 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JVC TV won't turn off
On occasion I will be unable to turn off my JVC Model AV-2659S. And then all of a sudden the same way it wouldn't turn off, it starts working properly. I have checked all the settings and can't figure out why it does that. Any ideas?
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Nov 21, 2008
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093721
Points
9665
It may be that the switch is worn out and needs to be replaced. Or your TV may have "Windex syndrome." This happens when people clean the screen by spraying on Windex and wiping it off like cleaning a window, and some of it runs down and gets on the circuit board front edge where the switches are. It can cause corrosion which leads to intermittent operation, strange behavior, or total failure of buttons. Best cure is to remove the board, inspect it, clean any corroded connections, replace the switches, and check the values of some of the small parts in that area. They can all be affected.
Jvc tv won't turn on
Check its main power regulator section for damaged component/s
JVC model AV-32750..... The close caption feature is toggled on and a large black square is blocking picture. I have no remote to enter the menu settings so using buttons on bottom front. I am unable to...
just look in the section for closed captions----the box is the "text" feature and just needs to be turned off; if you did it without a remote it can be undone the same way.
SD TECH
1helpful
JVC AV-F29MX3 I was watching a film on my DVD connected to the TV, when suddenly the screen turns black with no sound heard. Also the front light indicating 'ON TIMER' and 'ECO' started blinking in red...
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective .................. so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective.......... price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore ( 09986222774, [email protected] ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact jvc service centre.........
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
2helpful
3answers
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Goldstar TV (unknown model)
tv has a power supply fault requires service
Tv is locked
I have a Quasar Model AM 51760221 WP 3915YW 13 inch TV made in 1985. I am using cable and none of the codes work published by Comcast work to make the TV work with my black box. They are unable to help at Comcast. I did get an updated remote from them, but still unable to turn off the TV to use the remote/black box.
2answers
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
3answers
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Top Proton Televison & Video Experts
matt martin
matt martin
Bob Kirkwood
Larry
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
