20 Most Recent Proton MM2701VT 27" TV Questions & Answers
Do the picture to broadcasts appear correctly? Provide more details please.
Gopakumar Gopalan Google
Proton MM2701VT... | Answered on Apr 07, 2014
The fault is with its vertical scan output stage circuit. Contact any service technician. This is not a user reparable fault. [Out of Sync: picture].
Proton MM2701VT... | Answered on Feb 12, 2014
the start of tv set creates enormous static due to it`s initial ampere.it gives static mostly to a/m band radios.it is normal to the tv set while it starts.
Proton MM2701VT... | Answered on Jan 31, 2014
I hope the surge protector is separate from your TV. It has Varistors in it that are supposed to pass overvoltage surges (it can happen without the power going out) then recover to normal. But sometimes they overheat, then they can become a fire hazard. Or the contacts in the sockets can get charred and flakey. Anyway sounds like it is fried, the only easy solution is replace it. A careful tinkerer with a good scrounge box could fix it, if you know anybody like that.
Proton MM2701VT... | Answered on Jan 04, 2014
1-verify speakers-2-quit the intermed-frequeny sound coil,destroy the internal capacitor and replace for 100 picofarads, adjust.
Proton MM2701VT... | Answered on Oct 03, 2013
Check for bulged electrolytic capacitors in the power supply inside the tv.
Proton MM2701VT... | Answered on Feb 03, 2013
Does the tv have remote control? If is make sure did got wet somehow.
open remote control and check if is dry.
If a Mitsubishi (Proton is what is listed here) look on the back for the correct and full model number, no 54 inch sets, 55,60,73 etc.
Let me know if power light comes on for a few seconds and then goes off............
Proton MM2701VT... | Answered on Dec 15, 2012
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Proton MM2701VT... | Answered on Nov 29, 2012
test the main switch for faulty, and replace it .
God bless you
Proton MM2701VT... | Answered on Oct 12, 2012
Might be some loose solder terminal/s at its horizontal output section. The set should be checked.
Proton MM2701VT... | Answered on May 12, 2012
There is some short circuited component/s in your TV. It heed service. A skilled work indeed.
Proton MM2701VT... | Answered on Apr 24, 2012
open up and check for a dry joint at variable settings on chronos to screen controller if all cables ok ( check for pin damage on connector first sometimes a misalined pin prob
Proton MM2701VT... | Answered on Feb 21, 2012
my 42 inch sagem tv is overheating, the red light comes on, then 2 lights come on and then turns off, and light stays on. and only turns off when you disconnect tv. When i turn on the tv after 1 min the light flashes, the tv turns off and the light stays on.
Proton MM2701VT... | Answered on Dec 04, 2011
Problem experienced was not mentioned and so it seems we are not able to comment. Please post the fault seen with details.
Proton MM2701VT... | Answered on Oct 05, 2011
Proton MM2701VT 27" TV Logo
138 questions posted
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proton Televison & Video
Most Popular Question
sharp aquas t v about 3 years old turns
  • Televison & Video
