20 Most Recent Proton SRC-2010 LCD Touchscreen Remote Control Questions & Answers
Emprex uses the Memorex codes. They are 1002, 1004, 1005, 1010
Proton SRC-2010... | Answered on Jan 11, 2017
We would be happy to help you with that. Currently the onlycode we have that will allow you to control your Emprex TV is 597. If this codedoes not work we would recommend doing a power scan.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
Proton SRC-2010... | Answered on May 15, 2011
The original Proton SRC-2010 remote control is no longer available. However, you can purchase a substitute remote control which has similar functions.
To view the features and more details of the substitute remote, click on this link.
Also, you can call on 1-800-736-6837 to get more details.
Hope this solves your problem. Thanks for using FixYa.
Proton SRC-2010... | Answered on Dec 09, 2009
What is wrong with it.
Proton Televison... | Answered on Aug 02, 2018
The TCON board or the LCD panel is faulty. You have to change the tcon board to confirm the fault
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Proton Televison... | Answered on Nov 24, 2016
No. There no seperate fuse for backlighting.
Proton Televison... | Answered on Jul 06, 2016
Normally all the backlight inverters have fuse. It would be an SMd type.
Of you wish to get some more details check the link below
Back-light inverter board will have a fuse. Refer its circuit diagram to locate it. If it should blow up, there will be sufficient reason. Some short circuited components/s. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Proton Televison... | Answered on Oct 14, 2015
Proton SRC-2010 LCD Touchscreen Remote Control Logo
Popular Tags
9 questions posted
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proton Televison & Video
Most Popular Question
remote control codes emprex tv
  • Televison & Video
