SolutionFollow the given steps in the order presented to resolve the issue:
Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again.
Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
In the application you are printing from, click File
, and then click Print
Make sure the printer is selected, and then click Properties
Select the Paper/Quality
tab.
In the Print Quality
area, choose the next higher quality setting. If the current setting is
Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:
This step does not apply to color printouts.
Make sure the printer is selected and click Properties
Click the Color
tab, and select Print Grayscale
and High Quality
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
- Make sure the printer is loaded with unused white paper.
Open HP Solution Center
Click Settings
, Print Settings
, and then select Printer Toolbox
Click the Service Tab
Click Clean Printhead
, and then click Clean
Step five: Align the printheads
If the print quality is still bad, align the printheads.
Open the printer Toolbox
, and select the Printer Services
tab.
Click Align Printheads
. The Align Printheads window opens. Click Align
The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK
when the page finishes printing.
Step six: Calibrate the linefeed
If the print quality is still bad, calibrate the linefeed:
tab.
Click Calibrate Advanced Linefeed
. The Advanced Linefeed Calibration window opens. Click OK
Step seven: Replace one or both printheads
If
the print quality is still bad after performing all the above steps,
one or both of the printheads will have to be replaced. Print a PQ
Diagnostic page to see which printhead should be replaced.
Press the Setup
button.
Press 1
and *
simultaneously.
- Look
at the color blocks labeled Test Pattern 2. Some or all of them could
show white horizontal streaks. If none of the blocks are streaked, the
printheads are okay.
- If the Black block has lines – replace the KY printhead.
- If the Cyan block has lines – replace the MC printhead.
- If the Magenta block has lines – replace the MC printhead.
- If the Red block has lines – replace the KY printhead.
- If the Green block has lines – replace the KY printhead.
