20 Most Recent Epson STYLUS PHOTO T60 INKJET PRINTER Questions & Answers
Epson t60 general error
A "general error" with two red lights blinking on an Epson T60 printer can be caused by various issues, such as a paper jam, a foreign object inside the printer, a problem with the ink cartridges, or a malfunctioning of the printer mechanism. To troubleshoot this issue, try the following steps:
  1. Turn off the printer and unplug it from the power source.
  2. Check for any paper jams or foreign objects inside the printer and remove them if found.
  3. Ensure that the ink cartridges are installed properly and have enough ink.
  4. Check if any of the cartridges are damaged or expired and replace them if necessary.
  5. Clean the print head using the printer software utility or manually.
  6. Check the printer mechanism for any damages or obstructions and remove them if found.
  7. Turn on the printer and check if the error persists.
If the issue persists, you may need to contact Epson customer support or a certified technician for further assistance.
2/25/2023 9:18:31 AM • Epson STYLUS... • Answered on Feb 25, 2023
2answers
How I solve the Communication Error 21000068
Hi Rashid, Step 1 Uninstall the driver that you have installed recently. Open Devices and Printers by clicking theStartbuttonclip_image001.jpg, and then, on the Start menu, clickingDevices and Printers. Right click the printer-> Click on Properties-> click theDrivertab, and then clickUninstall. Follow the instructions. Now download the drivers from the following link and install it and check if it helps. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX425W/Drivers-Support Install the driver and check if it helps. Step 2 Try the Printer troubleshooter, which will attempt to automatically diagnose and fix your problem. Open the Printer troubleshooter by clicking the Start button, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Hardware and Sound, clickUse a printer. Next, try updating the printer driver on your computer. Printer problems sometimes stem from out-of-date driver software, and can be solved by installing-or reinstalling-the latest driver. Hope It's resolve all Your Printer Problem, Or Still having Problem Then follow Us For Epson Printer Support
2/18/2020 6:08:23 AM • Epson STYLUS... • Answered on Feb 18, 2020
2answers
Printer epson t60 the red light are always transferring to sides
you need to reset waste ink pad counter by adjustment program for epson t50 t60 printers
5/16/2019 6:01:12 AM • Epson STYLUS... • Answered on May 16, 2019
2answers
AdjProg Epson T60 model B412B
Hi, My English is not good, but i have problem how to download the Driver Epson T60 Model b412b. thank you !
12/6/2018 7:45:32 AM • Epson STYLUS... • Answered on Dec 06, 2018
Printing Problem & Troubleshooting Printer set as default Printer. Please solution me.
please call on toll free 1-877 213 6551 for support.
2/18/2016 6:02:46 PM • Epson STYLUS... • Answered on Feb 18, 2016
How i do solve comunication error
when he comes this error
11/24/2015 5:18:02 PM • Epson STYLUS... • Answered on Nov 24, 2015
HAVING PROBLEM IN SETTING
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures. Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it. 25606143-veth31alioz4nwkdghc1ewzl-4-0.jpg
4/25/2015 12:51:29 PM • Epson STYLUS... • Answered on Apr 25, 2015
MY PRINTER IS NOT PRINTING AFTER GIVING PRINT COMMAND?
Try clearing the print queue..
2/21/2015 8:15:41 AM • Epson STYLUS... • Answered on Feb 21, 2015
How to reset t6o Printer automatically
you have to get the adjustment program to reset it or use the wic reset download from the net and buy the reset key.
11/12/2014 1:34:28 PM • Epson STYLUS... • Answered on Nov 12, 2014
Two lights are on and off
which lights are on and off?
6/10/2014 3:43:53 AM • Epson STYLUS... • Answered on Jun 10, 2014
Epson expert
I would recommend that you buy a new printer. It is almost useless to replace components on those printers. You may have a print head or cable problem
3/18/2014 3:38:57 AM • Epson STYLUS... • Answered on Mar 18, 2014
Epson STYLUS PHOTO T60 INKJET PRINTER Logo
58 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Photo Epson
  • Photo Epson
Most Popular Question
epson t60 paper loading problem
  • Office Equipment & Supplies
