Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jun 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leak During a normal cycle - about 20 minutes in - washing machine starts to leak from what seems like the front right side of the washer. Had a repairman here to check the test cycles. There was no leak during these cycles. He checked the hoses etc. - no leak. Of course when I went to do a wash, normal cycle, the leak was back.
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Jun 20, 2008
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2735888
Points
22413
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
1helpful
My ZWD1471 started leaking during the drying cycle recently. It doesn't leak during the wash cycle. The water seems to be coming from underneath the back of the machine, I think on the righthand side. Any...
open it and see where the leack come from it might be the drain pump and it easy to replace or it might be a hose that got burst...
see if you can open it from the back or the bottom front
1helpful
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
Water leaking from Washer during cycle
you can remve a few screws(3) across the bottom of the unit.( just above your "add-on" drawer. 3 torx 20 screws and after removing the acess panel youll get abetter look as to where exactly you water is coming from
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
2answers
Moving
Don't know if you've done it, but put a level on the machine itself and make sure it is level. Adjust it front, back and side to side. This may cure your "walking problem".
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
