Samsung SyncMaster 214T 21.3" LCD Monitor Logo
Posted on Nov 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The 214T flickers for a few seconds and then goes black. Most of the time, after one hour or so, it will light up and stay up. During this time I am constantly turning the monitor on and off from the front control panel.
Steve
Level 2:
New Friend:
  • Expert 147 Answers
  • Posted on Nov 19, 2010
 Steve
Expert
Level 2:
New Friend:
Answers
147
Questions
Helped
34460
Points
454
Faulty power supply most likley, extended warranty?
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps, if so please rate our solution.
BuddyMc
1helpful
Flickering screen
The flickering problem you have is caused by a failing power supply. There are parts called capacitors that are failing and causing the power supply board to put out pulsing voltages until it can stabilize. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you can soldethen you should be able to do the repair yourself. If you don't want to do the repair we offer a repair service for this unit. You can get details for that service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
4helpful
My samsung 214t becomes very blurry after startup and flickers hard than falls out.after a while (first it was after 10 minutes and then it started to take longer than a half an hour the screen became...
The flickering is caused by a power supply board that can't stabilize the output voltages. This type problem is caused by failing capacitors. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you don't want to do the repair yourself we do offer a repair service for this model. The repair runs $30 plus shipping. You can setup the repair service at: http://www.ccl-la.com/blog/index.php/service-request-form/
CCL_Tech
Corporate Computer
www.ccl-la.com
Polaroid LCD on Digital Picture frame goes black during power-on
likely the old one had a bad inverter or a back light problem.
2answers
7helpful
2answers
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
