20 Most Recent Polaroid 4226TLMB 42 in. LCD TV Questions & Answers
Most remotes like that have a "Code Search" feature, and it's the easiest way to find the code.
Hope that fixed ya...
Geno
Polaroid... | Answered on Mar 03, 2019
Try another cable if you have one it may be faulty.
Polaroid... | Answered on Jan 24, 2018
Check the aerial installation is ok, try another aerial on the set, maybe an indoor one.If the set is analogue/digital check that it is set to the correct source, somebody may have inadvertently fet it incorrectly.
If all fails try resetting to factory default through the remote control menus, the option will be there somewhere.
If that does not sort it, you will probably need the services of a technician.
Two or three heads are better than one, ask friends for suggestions too
Good Luck with it
Polaroid... | Answered on Jun 17, 2015
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Polaroid... | Answered on Mar 04, 2015
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
Polaroid... | Answered on Sep 28, 2014
0270,0275. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Polaroid... | Answered on Apr 19, 2014
likely the old one had a bad inverter or a back light problem.
Polaroid... | Answered on Jun 11, 2012
As I understand it, Polaroid TV's sometimes work with the Mitsubishi codes. You may give this a try. You may also e-mail Polaroid direct at www.polaroidelectronics.com contact page to find out what codes should be used (may match a different manufacturer)
Polaroid... | Answered on Mar 09, 2012
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem.....
Polaroid... | Answered on Jun 16, 2011
That is more likely to be failing T-CON board or bad connection on the ribbon cable between the LCD panel and the T-CON board.
Learn more here:
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
PDF download: http://www.mediafire.com/?zzjygannjty
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Polaroid... | Answered on May 18, 2011
Look on the power supply for swollen capacitors. YOU will normally see 2 . replace with new ones. Also look at the heavy white wire that comes from the power supply, this would be your supply to lamps. I have had these burn and cause this defect.
Please leave feedback
Polaroid... | Answered on Feb 21, 2011
While the remote does not work with the TV, does the volume and other buttons on the TV works?
If the buttons on the TV works, then it means the problem is either from the remote control or the TV sensor/infrared.
Borrow a remote from a friend that uses the same TV as yours, use it to test the TV and if it responds, then you will have to get another remote.
If it doesn't work, then it means the sensor/infrared on your TV is the one that is failing.
Lastly, check your remote control, make sure the battery terminal is not rust, if its rust, use a flat screw driver to scratch it. You can further disassemble the remote control, check the panel in the remote and make sure there is no loosed wire or connection.
A thorough troubleshooting will direct you the problem.
Good luck.
Polaroid... | Answered on Oct 11, 2010
This problems u have.Most of the time is power supply board and the Tuner board require replacing.Because of massive power surges,go through the tv.Will,replaced the Tuner board first,might get lucky,but my experience,all the ICS in the power board and Tuner board are all dead.
Polaroid... | Answered on Aug 08, 2010
The problem you have described is an interference issue and not a problem with the tv. HDMi cables are ultra sensitive to electrical interference. Do you have a powercable running parallel to HDMI cable you use to connect your DVD player? Also check if there are anyother devices such as a microwave that can interfere with proper functioning of the tv.
Sai.
Polaroid... | Answered on Feb 01, 2010
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Check to see if you get any DC voltage on the output connectors.
Please post back what you find.
Polaroid... | Answered on Dec 17, 2009
there are flourescent tubes inside that can be replaced, they help to alluminate the screen. There are these other boards inside that can malfunction too, best to take the unit to a technician.
Polaroid... | Answered on Dec 13, 2009
Polaroid 4226TLMB 42 in. LCD TV Logo
43 questions posted
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
motel tv mode wehats code
  • Televison & Video
