Proscan 19LA25Q 19 in. LCD Television Logo
Posted on Apr 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought my 19" Proscan LCD (19LA25Q) used from a
Level 3:
  • Proscan Master 6,688 Answers
  • Posted on Apr 21, 2017
Cindy  Wells
Proscan Master
Level 3:
Answers
6688
Questions
0
Helped
3533260
Points
21745
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
5 Related Answers
Anonymous
  • 279 Answers
  • Posted on Sep 09, 2007
SOURCE: remote code
These are the Proscan codes I can find: 0047, 0060, 0760, 1060 Let me know if they don't work.
Anonymous
  • 133 Answers
  • Posted on Jul 12, 2008
SOURCE: finding a new remote
The most inexpensive solution, is to buy a universal remote. I own a One-for-All universal remote (model URC-4220) which works with Proscan TVs. I bought it at Walmart for less than 10 dollars.
You can also find a list of companies that sell Proscan remotes, by typing PROSCAN TV REMOTES into the Google searchbox.
These companies will charge you more money, for their remotes.
Hope these suggestions help you out. Please take a moment to rate the info that I have provided, by using the rating system below. Thanks.
Anonymous
  • Posted on Mar 17, 2009
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Jonny Pridgen
  • 42 Answers
  • Posted on May 10, 2009
SOURCE: Proscan LCD TV 19LA25Q stopped. Green ON light won't stay lit.
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
Chi Chu
  • 8457 Answers
  • Posted on Jan 01, 2010
SOURCE: need new power cord and remote dog chewed proscan
Try website 1-800-Remotes Factory original.For the remote.Try Partstore.com,Amazon.com,and Shopjimmy.com.For the A/C power coard.
Finding a new remote
Remote code
Proscan manual
This should help you
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Proscan 26LA30Q-screen will not turn on
This might help you
Remote
This might help you.
No sound from speakers
Info on the lcd tv's
2answers
Remote control
Universal remote available?
I can sell u a remote for the Proscan 19LA25Q 19" LCD TV .You can e-mail me at [email protected]
Remote control
get the tv code for the remote
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
