Dryers Logo
Posted on Jun 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer Cord melted....
Our Roper dryer cord melted. It is melted just in one of the prongs, but nowhere else. What could have caused this?
Is this a defective power supply cord and how do I get the company to repay me for the cost of the new cord I had to purchase and install?
The power Supply cord is:
Smart Choice (a check mark is also on the cord).
The number on the cord is: E184278-A AP-202 30A-125V/250V
andthe tag reads:
05/03 UL E184278
1Piece Power Supply Cord
Issue No. BW 8345
Printed in the U.S.A.
Any help would be greatly appreciated.
Thanks!
Carol
  • florence605
    florence605 Feb 10, 2012
    Quadmomma where did you find a replacement part?
Anonymous
Level 3:
  • Master 413 Answers
  • Posted on Jun 18, 2008
Anonymous
Master
Level 3:
Answers
413
Questions
0
Helped
209732
Points
1203
The power cord overheats and melts due to a failing power cord receptacle (the contacts loosen over time). To correct this problem, the receptacle and power cord should be replaced.
Need another cord to put on dryer as my home does not have the large outlet; only a 3 prong outlet. Can this dryer have a new cord put on?
Yes. Putting on a new cord is simple. There is a plate covering the cord that is on there now. Remove the two or three philips screws holding it on. Get a new cord at an appliance store. Use a nut driver to detach the old cord. Hook up the new cord with the colored prongs in the same places as the old. The green will be the one that is missing. Replace the green screw so it is not lost. Be sure to install the cord protector so the sharp edge does not slice through your new cord. Good luck.
I am replacing a 3 prong cord with a 4 since we have moved into a newer newer home and the dryer has a white wire attached to the frame instead of a green wire. Is the the ground and can I just place the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
1helpful
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Roper Dryer
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
2answers
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Top Dryers Experts
john h
